AMD HD 6990 @ Overclockers UK
Rossi~
http://www.overclockers.co.uk/showproduct.php?prodid=GX-033-HS&groupid=701&catid=56&subcat=1752
£569.99 inc VAT
£474.99 ex VAT
= 768.791 USD (minus EU rape will put it closer to $700 most probably)
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
Also
http://www.overclockers.co.uk/showproduct.php?prodid=GX-257-SP&groupid=701&catid=56&subcat=1752
£589.99 inc VAT
£491.66 ex VAT
Features:-
- ROPS: 64
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Rossi, you going to buy one or two? ;)
I'm tempted to get one, but i'm a green fan :p Though looking at the reviews my god this is a nice card. I'm waiting to see what the GTX590 is like :)
I hope you have a good set of noise cancelling headphones according to the reviews. :D
I was planning on getting 2 of these and Water Cooling them anyway. Sound issue gone.....but the power draw would be too much for my wallet.
Not sure what to do now...might just keep my 5970 and possibly get another.
