griff30
- Jul 15, 2000
Just got my FX-8130 to upgrade my kids gaming machine. I got the Tiger direct deal. With rebate it comes in under $100 for 8 cores.
I thought this would be a cheap upgrade for his system which is:
Fx-955 3.2 ghz EVO 212 Cooler.
Gigabyte 990FX UD3
2 GTX 460s in SLI.
16GB ram
950 Watt Corsair PSU
Corsair SSD
I also picked up a used R9-270 on here for upgrade.
The FX-8310 with R9-270 is slow and unresponsive.
It overclocks to 4GHz but every benchmark is slower than a stock 955 @ 3.2
It will literally stop showing what you type in a webpage. The benchmarks come in at half the score of the 995 with 2 GTX 460s.
Not sure if its the used R-9 270 or the new CPU causing this. Likely someone mine the shit out of the R9. After work Im going to go back to the SLI cards with the FX-8310.
Sandra reported that the CPU was getting only 94 watts I might need to bump it up.
Any suggestions?
Gigabyte 990FX UD3
2 GTX 460s in SLI.
16GB ram
Corsair SSD
Any suggestions?
