Well the benches are out on the desktop parts. Looks good.
http://www.tomshardware.com/reviews/a10-5800k-a8-5600k-a6-5400k,3224.html
No really: "Piledriver still gives up significant instruction per cycle throughput compared to the older Stars design, but is better able to compensate than Bulldozer."
Personally I don't consider lower IPC than stars "looking good".
Not bad. I'm still not expecting it to surpass Intel performance levels, even with a 4 module version.
They must be using the i7 7 core naming schemeSo where are the 10 cores?
They must be using the i7 7 core naming scheme![]()
The benchs show trinity quads. I want to see octa and 10 cores pwn i7s!!!
lol. I just want to see the power draw when OC . IPC improvements are about all that could be expected. IF the power isn't outrageous we might actually have a alternative to the ubiquitous i5 when the 8350 is released. As awesome as the Z77+IB is, it is still boring when everyone is basically forced to use the same hardware. Intel CPU OC are easier than ever before, RAM timings are increasingly meaningless and we have GPUs that OC themselves. Hopefully AMD can bring some fun back to being [H]. The upcoming i3 vs A8 reviews will be interesting too. It may not be an Intel killer but it is nice to see them follow through on expectations this time.The benchs show trinity quads. I want to see octa and 10 cores pwn i7s!!!
THG said:How about Trinity’s built-in graphics component? Clearly, this is one of AMD’s greatest strengths. We know from our Core i7-3770K review that HD Graphics 4000 can’t even keep up with Llano. Pile on frame rates that are 20 to 25% higher than the first-gen APU and you have the prelude to a blowout favoring AMD's Trinity. Of course, there aren’t any Intel processors with HD Graphics 4000 selling where we’d expect to find these upcoming APUs, making HD Graphics 2000 or 3000 a more realistic comparison.
Don't know whether you're being serious, or just trolling...
You do realize that Trinity is a low-end part, not meant to compete in any way with the i7s, right? That will be Vishera's job.
Trinity: budget/mainstream, has an iGPU with up to 4 cores (2 modules). Uses FM2 socket.
Vishera: mainstream/enthusiast. No iGPU, up to 8 cores (4 modules). Uses AM3+ socket.
Vishera using Piledriver cores will be using AM3+. It is also rumored that Steamroller, the 28nm die shrink, may also appear on AM3+, but nothing is confirmed.
I believe the rumormill only shows am3+ and FM2 for AMD until DDR4.
Cool, but I dont think Ill be upgrading on realease. My thuban can handle any game out right now, Im saving money for a 7990, that would make a better upgrade.
In response, AMD officially adds support for up to DDR3-2133 with one module per channel, or DDR3-1866 with two modules per channel installed. In comparison, Llano topped out at DDR3-1600 with two modules per channel.
let me get this straight, i will be able to run two dimms at DDR3-2133 in dual channel mode on a trinity board.
did i understand this correctly?
pretty much, since AMD isn't pushing on processor pci-e 3.0 support like intel has AM3+ has a couple years left in it. same goes with G34 on the server side. and like you mentioned the only other socket change is FM1 to FM2 on the APU side for the same reasons they had to switch from AM3 to AM3+.
interesting review up until this part...
"This ones all-new. Corel revamped the WinZip engine, better-optimizing it for multi-core processors (in addition to exposing support for OpenCL on AMD GPUs, which we'll test shortly). Were certainly not fans of a company using an open standard to lock out competition. Further, we know that AMD was instrumental in exposing this functionality, and thats the justification given for preventing Intel or Nvidia from benefiting from it."
lol seriously? AMD isn't preventing anyone from using openCL, Intel and Nvidia are preventing themselves from using it. its an open source standard that they refuse to implement into their products, there is absolutely nothing AMD is doing to prevent them from using it.
I basically looked at 8150 benchmarks and added 22% to them (+10% because I'm assuming the top Piledriver will be clocked at 4.2, and +11% for IPC) and the hypothetical piledriver benches often looked really good. Competing well and beating intel chips at times
PCmark 7 overall suite score
3770k=5487
2550k=5079
8150=4189
8150x1.22=5111
PCmark 7 productivity suite score
3770k=5436
2550k=5103
8150=4105
8150x1.22=5008
Creativity suite score
3770k=5655
2550k=5138
8150=4792
8150x1.22=5846
i'd still worry about the chip most of all in gaming, the very thing we care most about. even a 22% speedup is still going to leave it looking a little sad next to intel in some gaming benchmarks. that said i even see a silver lining there, which is that in the future more games should start using more than 4 threads, so bd/piledrive/steamroller might start looking better and better at gaming over time if i'm right as games start using up to 8 threads.
I read this recently , forgot where though, that Trinity isn't a "full" PileDriver core, but something between BD and PileDriver, and that the next AM3+ chips will have the full PD Cores which should push IPC up more than Trinity.
the addition of 8MB L3 should also give PD for desktop (Vishera) slightly better performance. not sure if you factored that in your 22% figure. should be worth a few extra percentage points.
that travesty from MS (win8) might actually give reason for those of us with current AMD hardware (AM3+) to upgrade from windows 7. that is if win8 indeed has a better scheduler than 7. if the gain is only a ~1%, will happily stay with windows 7. however if the percentage increase is greater, will need to look at ways of un-doing the 'metro damage' unless of course one actually likes the win8 UI
in any case AMD might have given rise to some 'quiet optimism' for their new CPU. at the very least has given us something (positive) to think about. the 'AMD Processor' sub-forum has been pretty quiet lately.
another consideration if AMD's new PD proves competitive on the desktop, Intel may need to re-think their intentional CPU gimping (using thermal paste between the core & IHS instead of solder comes to mind).
I think you may be referring to this report from xbitlabs.
http://www.xbitlabs.com/news/cpu/di...rt_Production_of_Next_Gen_FX_Chips_in_Q3.html
"For example, only fully-fledged "late" Piledriver inside Viperfish model 2xh will be able to execute numerous new instructions as well as will receive instructions per clock (IPC) increase. Even though reduced "early" Piledriver inside code-named Trinity APUs model 1xh will be more advanced than the original Bulldozer model 0xh, the x86 cores are projected to be slightly less efficient than those of the full Piledriver."
