Building a new rig so my sig other can game a little. Aion's probably the most demanding thing lol
$200, but I'd like it to be way cheaper if possible
3) Where do you live?
Pittsburgh, PA
(not originally from here)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU and Mobo that can use DDR3
I have everything else I need, but I am specifically look for a cpu/mb that can use DDR3 as I have some extra
6) Will you be overclocking?
I'd like to hit 3.5-3.6, but Its not necessary
1440x900
I plan on waiting for deals in the for sale section here and elsewhere aka I'm not in a hurry
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
1 PCIe 2.0 x16 for dual slot GPU and one available PCI leftover.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes Win 7 x86 and x64
I'm thinking about building another system for my significant other for light gaming. I was thinking something like a Phenom X2 555 BE, Athlon x4 635, or Athlon x3 425. Its been a few years since I had an AMD system, so I've really been out of the loop. Should I go with one of these or could I get away with something less? I realize I can't go too low or it won't work on DDR3 boards.
Thanks in advance!
Errr updated in last post
Pittsburgh, PA
1440x900
Thanks in advance!
