I found a 5700+ resolution bench with 6970 Crossfire
http://www.kitguru.net/components/c...on-8-core-review-with-gigabyte-990fxa-ud7/23/
Strange request, but when you guys do the second round of gaming benchmarks, is there anyway to disable the cores so you can run it at 1 core per module for a test? I'm just curious how that'd effect gaming performance, given basically no games use 8 cores properly and people are reporting (http://www.overclock.net/15288816-post1604.html) that the module sharing penalty is pretty big and worth avoiding if you're not actively using more than the 4 cores.
It's not all that practical, but my nerdness is curious what actually happens. I have my doubts dropping 4 cores will really help at all, but I'm intrigued anyway.
I guess that answers the question, 20-30% performance increase in single threaded (and presumably up to 4 threads) workloads if module sharing is turned off.
So does that mean the whole module sharing idea is a failure, or is it just poor implementation?
You obviously have no idea what you are doing. A 1090T runs WoW just fine. Hell, a Pentium-D would run WoW just fine.
Well, of course I'm disappointed that AMD didn't kick Intel's ass. However, much like the Phenom I, the B3 stepping will probably fix quite a few issues. No miracles likely, but we may see some improvements, judging by how much there is to fix.
It won't. There is nothing to fix - this is a issue with the architecture itself. It's like waiting for a fixed Radeon HD2900XT, which never came. Maybe Piledriver will be to Bulldozer what HD3870/4870 was to HD2900XT, maybe not. But waiting for some "magic B3 revision" is pointless. Get yourself a Phenom II X6 while you can, or use Intel.
You didn't get it - there is nothing to fix in Bulldozer as is. The fix is maybe what we call "Piledriver". There won't be a "new revision of Bulldozer". Phenom got a new revision because it had a error which was significant for usage - a blocking issue. High power consumption or low performance aren't a blocking issue.
And what is your super overclocking worth, when your 5GHz 8-core FX 8150 equals to 4GHz 6-core X6 1100T in performance ?
You're absolutely right, Rome wasn't built in a day. But AMD took 4 years to build a pile of shit CPU
Those benchmarks are absolutely embarassing. If this is meant for server performance, I'd like to see some SQL #'s and maybe web transaction #'s. But in the end, this is a bomb. Such a shame
I reacted to "However, much like the Phenom I, the B3 stepping will probably fix quite a few issues.", where i simply don't see such "stepping" or "revision" comming, which would fix the subpar single thread performance. And even if such things comes sometimes durring Q2/2012, it will be already too late for AMD, because their opponents won't be Sandy Bridge, but Ivy Bridge and Sandy Bridge-E.
Even now, the best they can do at high overclock is to level up with non-HT Sandy bridge CPU at stock in real world use case scenarios. The single core design they put in Bulldozer is simply flawed, and can't be just "fixed in stepping". Unless you call Piledriver as a "stepping".
