AMD 64 system boot up problems & RAID
3WAYsplit
AMD 64 system boot up problems & RAID issues
Windows XP Home
GIGABYTE "GA-K8VNXP" K8T800
AMD Athlon 64 3200+
MSI nVIDIA GeForce FX 5900XT Video Card, 128MB
Creative Labs Sound Blaster Audigy2 ZS GAMER
Maxtor 200GB 7200RPM SATA HDD
Plextor 12X DVD+RW/-RW Drive
Asus 16X DVD-ROM Drive
FDD
SAMSUNG 173V-Silver 17" LCD
When I first started my system I put in Windows XP CD, and I got
a message that the install will stop because no HDD were found on this system... So I assume that I need to "format" the new HDD's but being
SATA Im not sure how to do it and they are going to be set up in a raid
array...
I think I was able to get the drives to be set in the raid, are they formatted??
Could it be possible that they are not set up right, how do I change them?? Do they have to be set up in the raid??
When I boot it up, it sees everything. The boot screen goes though the normal process but it stops with this message:
Verifying DMI Pool Data....
When it does get past that message, it gives me this message:
No HPA Enabled Drive Found, Press any key to boot
I need to format these drives, I would appreciate help. This is my 1st time using SATA drives and raid...
Im dont have any IDE HDD connected, and I dont have any availiable to use...
Please help me get these SATA drives setup..
:confused: :( :confused:
You might want to check Gigabyte's site for a set of drivers you need to slap on a floppy. Then during the time XP's install tells you if you need special hardware drivers and press a key (it's been a while, might be F6), press that key and stick that floppy in the drive. It'll load the drivers from the floppy and continue only this time, hopefully it'll find your drive(s).
I'm not sure if this is the case for the Gigabyte mobo you have but one thing to look out for is that with the Asus SK8N I have, there's a driver set for SATA if in RAID and another set if not in RAID. If you're stripping them, make sure you download and use the right drivers.
Good luck and welcome to the world of Athlon 64s. :)
