AMD 5850 and HX620
jon_k
I just bought a new AMD 5850, but I'm worried it won't work on my PSU (Corsair HX620)
My PSU only has one 6 pin PCIE connector and the 5850 needs two. Is this going to be a problem?
The 620HX has two PCI-E connectors. Check again.
If you did lose that second PCI-E connector, most good HD 5850 manufacturers should include a molex to PCI-E adapter
Posted via [H] Mobile Device
Also contact Corsair about your missing cable. They should take care of you.
Your HX620 should come with two PCI-e inputs. I know my HX520 does which I will be using with a 5850 next year. You should probably contact Corsair to see if you can get another.
