To be fair though, it's not like the performance gains from the instructions are going to be noticeable going forward.
Note there are plenty of Glide wrappers out there, for those games that require Voodoo support.
Those "Glide wrappers" still do not perform nearly as well as a Voodoo 3/4/5 will in old games though..Although if OP is looking for a modern setup and has an AGP based V3/4/5 I would look for a socket 939 X2...They perform well enough (coupled with an SSD) for general use and will crush old native Glide games...If he is using PCI based Voodoo 2s, well I gues
s he can go much more modern...
Pretty sure the Phenoms were. My 965BE did and looking at CPUboss shows that Phenom did support 3Dnow. Dropped support with the FX series.
