"Every indication we have thus far is that Piledriver is faster than Bulldozer at the same clock, yet still slower per core than Thuban..."
....in Cinebench.
They need to ditch the AM3+ socket and all the bullshit that goes with it.
Zarathustra[H];1039194188 said:Not a big fan of HT, eh?![]()
Another person said it's probably one, well one of many, reasons why there isn't PCI-E 3.0 native on the processor or the chipset-- lack of bandwidth from the HyperTransport bus. Trinity has an on-die northbridge with a single x16 PCI-E interface for the PCI-E slots. A lot of the changes done to Trinity also necessitated a new socket. I think doing away with HT on Trinity is the start of one of many changes in AMD's future processor line, but we may not see those changes immediately.
But, that's going to be years away from now. One person in the Trinity reviews noted we won't see AMD catching up in single threaded performance until Steamroller or after that, so within two or three years.
Zarathustra[H];1039194321 said:They have given up in competing against Intel in x86 performance, trying to carve themselves out a lead in the APU market instead.
It's the only thing they have a realistic shot at doing unless another Next Gen Systems is found and AMD can buy them up fast enough to implement the technology before it becomes obsolete anyway. People often forget that AMD has virtually always been behind Intel in terms of performance and the one time they really weren't, they were using technology bought from someone else and engineers who worked for a more competitive company. (Digital Equipment Corporation or DEC.)
Zarathustra[H];1039194536 said:While this seems like a huge lost opportunity when it comes to the CPU space, maye it was the correct business decision to spend that money on ATi and get into APU's, I'm not sure.
Is AM3+ technologically behind in some way? My brand new ASUS SABERTOOTH 990FX R2.0 with a 965BE idles at 68 Watt at the wall despite all its new digital power stuff, whereas my GIGABYTE Z77X-UD5H idles at 33 watt. The VRMs on the z77 are barely warm, but the Sabertooth draws 200+ watt full throttle.
Zarathustra[H];1039195023 said:I noted this as well.
It is particularly interesting when comparing the new Trinity FM2 CPU's to FX Bulldozer AM3+ CPU's.
They are a similar enough design that you'd expect similar idle power draw, yet for some reason FM2 idles at ~30 Watt and bulldozer idles at ~70 watt.
Maybe HT uses a lot of power?
Trinity FM2 uses an integrated northbridge like current Intel CPUs, so that is probably a major factor in the lower idle power consumption. AM3+ still has the northbridge on the motherboard.
yet CPU power consumption alone at idle does not account for the diff at the wall.
Some PSUs are really inefficient at super low wattages. I built a custom EPS splice-in cable (simultaneous V*A) just so I could actually measure the CPU power alone. But if the motherboard is hungry, not much one can do (like my 920's asus P6T deluxe).
The GPU has a separate interface for sending memory requests that target the coherent system memory. The Fusion Control Link (or Onion) is a 128-bit (16B) bi-directional bus that feeds into a memory ordering queue shared with the coherent requests from each of the 4 cores. Onion runs at up to 650MHz for notebook variants of Llano (10.4GB/s read + 10.4GB/s write) and 492MHz for Zacate. An arbiter in the IFQ is responsible for selecting coherent requests (based on memory ordering) to send to the memory controller. Desktop versions of Llano will probably run Garlic and Onion faster still, given the extra power budget.
The memory controller arbitrates between coherent (i.e. ordered) and non-coherent accesses to memory. Llano has two 64-bit channels of DDR3 memory that must operate independently, while the smaller Fusion cousin only has a single channel. The GPU memory is interleaved across both channels for maximum streaming bandwidth and requests will close DRAM pages after an access. In contrast, system memory is optimized for latency and locality; contiguous requests will tend to stay to one memory channel and keep DRAM pages open. The memory can run up to 1.86GT/s for a total of 29.8GB/s memory bandwidth on Llano. It also contains an improved hardware prefetcher that tracks 8 different strides or sequence of strides and speculatively fills into the memory controller (rather than the caches).
In contrast, Sandy Bridge has tigher integration – using the on-die ring interconnect and L3 cache. Data is passed through the ring interconnect, but can be shared either through the cache or memory. The ring interconnect is 32B wide with 6 agents and operates at the core frequency (>3GHz). Data usually coming from either the 4 slices of the L3 cache or the memory controller, which resides in the system agent. The peak bandwidth is over 400GB/s, but the practical bandwidth since many accesses have to go through multiple stops on the ring interconnect. The Sandy Bridge power management is also fully unified for both CPU and GPU, so that when one is idle, the other may ‘borrow’ the thermal headroom.
Haswell, if Fudzilla is correct, will have its own VRMs on-die. I think it was posted in the Intel forums here as well. There was some controversy about this because some thought this would kill off enthusiasts who like to overclock their processors.
They're not integrating all of the VRMs on-die. I believe it's only minimal integration for Haswell, though this will certainly pick up later on.
Frankly, I'd take the decrease in power consumption and higher stock clocks and IPC over extreme overclocks. People overclock for the fun of it, rarely because they need the extra performance (which can be solved by even more aggressive turbo scaling, btw).
I've always thought it was more fun to see how much you can get out of very little power![]()
I don't care how much electricity the thing uses or even how much heat it generates so long as I can dissipate it sufficiently. I want maximum performance and I don't really care how this is achieved.
crappy TIM? Who gives a shitIs it cheap? Use it.
Think about the Sandy and Ivy CPU architectures. Great performers, sure, but where were they even better? The graphics capabilities were 2x greater than the prior gen and the efficiency improvements were stellar. Those are mobile goals, not desktop enthusiast ones.
The days where overclocking, high TDP, high clock speed processors were the design goals have been left behind years ago. Haswell is an efficiency architecture first and Intel made a point of stating the architecture is shared throughout all of their products. That trend is going to continue
-- I also think it's a bit silly to think of overclocking as an enthusiast-only shindig. How hard is it to overclock today? Any idiot can do it. It's not like the olden days where we needed a graphite pen. Those were the enthusiast days, today's overclocking to 4.5ghz is akin to tying your shoes.
Zarathustra[H];1039197650 said:I thought this was pretty much not the case with IB, just suspected early on.
From what I recall, reading the threads on the forums from people who removed the cover, wiped the TIM and replaced it with a direct on chip cooler and good TIM, found that their results didn't improve much or at all...
You stopped reading after the first random person did this. There have been several others that have delid their IB with great results. That first guy is essentially the only person who didn't get results iirc.
The days where the majority were in your shoes has greatly diminished. Intel's chasing the money, and that means using a single overarching architecture and core design throughout all of their products, low end to desktop. Considering the rather huge lead they have over AMD in the desktop and server arena, they're not going to really care about the enthusiast much. -- crappy TIM? Who gives a shitIs it cheap? Use it.
I don't see how the VRMs could be on-die ... that would greatly increase heat density. Maybe it works for stock, but it would kill overclocking without water cooling.
The idea is better power usage and TDP.
I'm going to guess here since I don't remember the entire reasoning behind this, but it's to do several things:
If you recall, more and more processors in the last few years have had the ability to shutdown certain parts of the processor to get better power efficiency and performance-per-watt. We've seen this a lot with Intel's Sandy Bridge and then Ivy Bridge. AMD has done similarly to its FX processors beginning with Bulldozer based modules and its Llano APUs. For both companies, though their implementations are different, come down to the ability to shut off cores and graphics cores (if on-die GPU exists); to lower or raise the frequency of the processor depending on work load; and if in the case of Intel, the ability to shut off certain parts of the core itself.
- Reducing board parts for increased efficiency.
- Better power regulation based on work load and temperature.
- Ensuring that when the load increases, processor can automatically and properly clock up or down as long as it stays within its max TDP by using as little power as possible for each processor state.
An on-die VRM is meant to give the processor more control over how much voltage it uses when it does any of its power-saving features. And, that's where all the red flags were being thrown up in the air by overclocking enthusiasts. Does that mean that enthusiasts will not be able to properly overclock their processor anymore? Does that mean they can't increase the voltage of the processor as they bump up the frequency? Will Intel's on-die VRM implementation prevent unnecessary voltage increases?
It's a bunch of things that some users on another website were and still discussing about. We won't know for sure until sometime next year when Haswell is released somewhere in the first half of 2013.
But, when you read something like this, where Intel's Haswell graphics part does the same amount of work at 7W as Ivy Bridge's 3000-series HD graphics core does at 17W, is really impressive how far Intel has gotten in increasing performance-per-watt efficiency. That and Haswell's processors will be rated between 35W to 77W TDP like Ivy Bridge, with 100W TDP reserved for higher-end processors. Just going by this alone, a Socket 2011 Haswell may use a lot less power than a Socket 2011 Sandy Bridge or Ivy Bridge processor.
What we may see out of LGA2011 Haswell CPUs is a power envelope that's not too different from today's current hex core parts, but with 8 cores or more. Though I'd expect idle efficiency to be a bit better than current generation parts are.
SoC improvements. On Intel's recent IDF they made a point of stating they're using a single architecture throughout their product lines. The efficiency improvements needed for the low end are going into their high end processors. Remember that they're still a ways away from getting x86 down to a level where it's both efficient on power and cheap.
That 10W Haswell chip sports a GT4 iGPU. They also said the improvements on the 17W Haswell GT3 are about 30% over the same ULV Ivy processor.
That would be impressive right there.
I remember reading something about that.
