dream caster
- Aug 12, 2001
This will be kind of a tinkerer's toy. I plan to use it for internet, light gaming; I´ll try to run FreeSpace2 in virtualized W98 and I want to overclock some and experiment towards a fanless PC.
I live in Chile. In the USA you live in the paradise of computer buyers, my hardware list costs here the equivalent to about $340 US dollars; I suppose in USA it would cost about 40 or 50% less. And now after the crisis the component stock, that was rather good, has diminished a lot, specially what would be upper mainstream parts the cheapest and most expensive parts are easier to find.
I will be buying:
motherboard Gigabyte MA790X-UD4P
CPU X2 7750 Black Edition
RAM probably 1 2GB 800MHz PC2 6400, some more later; Buffalo seems the cheapest
DVD drive
Video card: a Radeon 4670; probably will be a Saphire, I will choose what is available locally
I have
PSU: Corsair VX 450W
some old IDE HDD (2 IBM DeskStar 20GB), one of them will do for now
PS2 mouse and keyboard
I will use an open case I'll make from mdf, some steel cut from old computer side panels and some aluminum
I contemplate some overclocking mostly to test heatsinks; first with stock cooler then I plan to try scratch make heatsinks.
As for now I have a 19'' CRT monitor and I eventually would like to have something like the Dell 2408FWP.
I would like to build this as soon as I get the motherboard that here is difficult ot get.
I plan to use Ubuntu and a virtualized Microsoft OS. I have W98SE, W95 and a legit DOS 6.2 (it has never been installed)
My deciding point has been looking at the Gigabyte MA790X-UD4P motherboard and feeling it is what I'm looking for; it must be durable, I want it long lasting; with connectivity and upgrade options, a rather easy way to cool mosfets and it should be not too expensive.
How will virtualization work? what memory choose?
I will be buying:
DVD drive
I have
