AM2 motherboard question:
sektor
I just picked up a ASUS M2N-E board. I'm a little leary of it, as i've read a mix bunch of reviews; some good, some bad, which I guess could be said about any board.
Anyway, this Monday price cuts are coming and im looking forward to my new CPU.
But, im starting to wonder, is there maybe a better AM2 board out there? One that is pretty good at OC'ing? I don't need anything extreme like, but something that would let me push the CPU a bit so I can get more out of it.
Does anyone have any feedback on this particular board? Is there another board I should be looking at?
I appreciate it.
Try this site:
http://asustech.15.forumer.com/
From what I have read, most issues on that board have been solved with bios updates, make sure you get the latest bios before doing a install. Hook up the bare minimums, (HD, Video, Ram) first, update bios then install Windows and rock on! ;)
Asus is shiznit!
I'd say that the Asus board is as good as any other for AM2 right now if you don't need SLI.
Ya, I don't need SLI. That is a big reason why I purchased it.
Want a board that will allow me to overclock whatever CPU I decide upon a little bit. For example, if I purchase the 3800+ x2 (which I think is 2.0ghz?), I'd like to get it up to 2.6 if possible.
I think that Asus board should be fine for that kind of OC.
