AM2 Mobo decision (2.0+VDIMM)
lightsourcex
I need to know, what motherboard can I buy that is around $130 that has 2.0VDIMM or more and will work with G.SKILL 2GBLA Memory, and if you can manage no gigabyte or msi, and if it IS gigabyte or msi, please give a review on the product that you suggest.
And if you guys/gals can't find a board within my boundaries/filters please find a review/testimony to see if the FOXCONN C51XEM2AA will support the memory I have chosen.
MOBO - ??? - NOT BOUGHT
CPU - AMD Athlon 64 3800+ Windsor - NOT BOUGHT
RAM - G.SKILL 2GB DDR2 667 -NOT BOUGHT
VC - eVGA 6800GT - BOUGHT
PSU - OCZ PowerStream 520W - BOUGHT
HDD - Seagate Barracuda 7200.10 320GB - BOUGHT
CD - BenQ 16X DVD±R DVD Burner - NOT BOUGHT
HTSNK - ZALMAN CNPS 9500 AM2 - NOT BOUGHT
CASE - Lian Li PC-7B plus II - BOUGHT
SYSTEM STATUS:
44% COMPLETE
Is there a reason you're going with DDR2 667 memory instead of DDR2 800 memory? The prices are similar.
The regular Athlon 64 AM2 chips only support up to DDR2 667. (or at least thats what it says in the August issue of Maximum PC.)
Yes, the boards will handle DDR2/800, but if you are using a single core AM2, it won't take advantage of it. (unless you overclock to DDR2/800 speeds or something)
AMD's single-core Socket AM2 CPUs can handle DDR2 memory at speeds up to 667 MHz, while the dual-core models like the Athlon 64 X2 and FX-62 can accommodate DDR2 DIMMs up to 800 MHz. Like Socket 939 before it, Socket AM2 has the ability to host dual memory channels so that memory accesses are effectively 128 bits wide. Poke around on the calculator a little bit, and you'll find that combination gives single-core Semprons and Athlon 64s over 10.6 GB/s of total memory bandwidth with DDR2-667, up from 6.4GB/s with a dual-channel DDR400 config. With dual channels of 800 MHz DDR2, the dual-core chips have as much as 12.8 GB/s of memory bandwidth, fully twice that of the previous generation.
Quoted from Techreport.com
So you didn't planned to overclock it right?
Well you should considered doint it since it a lot of fun, and pushing your system to the max makes you get better system that you pay for :D
Umm... Not really, I thought about getting DDR2 800, and it's what I actually wanted but everything I've found is just overpriced for my budget.
Double checked and I found one thing:
G.SKILL 2GBNS.... Problem?
For Intel Platform only.
So, I'm back to 667. Unless you can find somthing for 150 that is amd compatable.
Yes I plan on overclocking, I overclock everything that I have that IS overclockable, I just wasn't really worried about that considering I'm trying to get my 6800GT to a workable motherboard becuase I have AGP right now and I ordered the 68GT for $100 but I can't use it because I don't have PCIe.
