ElvishBoy311
- Sep 24, 2001
What is the stock heatsink that comes with an am2 processor? Also, do 939 heatsinks work for am2 in case I want to upgrade?
-=Antimatter=- said:The stock heatsink that came with mine is an aluminum block with a 60mm fan on top. It's about 3in tall and a good couple hundred grams. Kept my single core at 15C idle/18C load, according to the BIOS and AMD's Dashboard. The Zalman CPNS9500AM2 keeps it a few degrees cooler if the BIOS is to be believed.
70mm.-=Antimatter=- said:The stock heatsink that came with mine is an aluminum block with a 60mm fan on top.
Wow your onboard sensors are bork. That is not right at all. You may want to give the manufacture a call.-=Antimatter=- said:The stock heatsink that came with mine is an aluminum block with a 60mm fan on top. It's about 3in tall and a good couple hundred grams. Kept my single core at 15C idle/18C load, according to the BIOS and AMD's Dashboard. The Zalman CPNS9500AM2 keeps it a few degrees cooler if the BIOS is to be believed.
