Hey, all.
Looking for some clarity on a budget AM2 build primarily geared for graphics/photo/multimedia and some light gaming. Not really interested in OC'ing.
I've already read a number of the Budget Box Guides/threads at various sites (ArsTechnica, Tom's, Anandtech, here). I'm coming from a low-end s754 setup.
I've been debating between a few sub-$100 mobos. These nforce 550s:
- ABit KN9S (http://www.newegg.com/product/product.asp?item=N82E16813127007)
- MSI K9N Neo-F (http://www.newegg.com/product/product.asp?item=N82E16813130050)
And the only 570 Ultra really in my budget:
- Asus M2N-E (http://www.newegg.com/product/product.asp?item=N82E16813131022)
I didn't include the Biostar TForce 550 as I'm generally not a big fan of Biostar, and it's not really much cheaper (even with the 'egg combo deals). And the MSI K9N Platinum non-SLI (570 Ultra) doesn't seem to be available anymore.
I also recently came across this apparently older Asus M2V (VIA K8T890 chipset): http://www.directron.com/m2v.html#caption
How does the K8T890 compare with the nforce 500s?
Should I also be looking at the nforce 4 boards? I figured the 500s would be better as the newer chipset designed explicitly for the AM2 socket. Maybe I'm wrong.
Nevertheless, I was initially leaning towards one of the 550s, as that would allow me to spend a little more on the processor (like an X2 4600+). And at stock speeds there doesn't appear to be any differences betweeen the various nforce 500 series chipsets (at least according to this piece: http://www.tweaktown.com/articles/950/16/page_16_final_thoughts/index.html)
Reading up more on the differences, I'm not sure if the M2N-E (and 570 Ultra, in general) may ultimately be better for me, even though that would pretty much limit my CPU choices to the X2 3800+. I don't need the extra Ethernet port, and 4 SATAs should be enough, but the FirstPacket and TCP/IP Accel. sound intriguing as I do use VOIP and once in a while do some LAN gaming, in addition to multitasking. But I don't know how much of a benefit these techs. really would be in practical terms.
The main advantage seems to be that the 570s are compatible with FX CPUs, while the 550s don't appear to be (as specified here: http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2764&p=2 and elsewhere, though some of the nforce 4's say they are. Confusing.). If I wanted to upgrade in the near future, that would give me some more options (X2 or FX) as prices continue to drop and the newer AM2+ gear comes out.
So, the M2N-E would appear to be a decent compromise, but the memory voltage issue is something of a turn-off. With mostly higher latency RAM available at 1.95v and below, it seems to limit upgradeability in that respect, as the low latency, higher spec'd sticks are all higher voltages.
Is this still an issue with this board? Or has it been remedied in current versions?
Last question regarding memory and multipliers -- was reading about the fact that with CPUs with even multipliers, it seems to be better to go with DDR2-800, and for odd multipliers, DDR2-667 (http://tinyurl.com/yw9c3r -- Black Jacque's post in particular). With the new Brisbanes having half-step multipliers, how does this affect memory choice?
Is this only an issue for hardcore OC'ing? Is this really an issue at all?
Apologies for the length of this. Just trying to get a better grasp on my options. Been out of the mix for a couple years.
Thanks ahead of time.
