Alternative to Abit IP35-E
celwin
Can someone suggest an alternative to the IP35-E for under $100? Since I can't find a IP35-E under 100 figured I'll look elsewhere. Thanks
I believe this model is exactly the same as the -E version but with firewire, http://www.mwave.com/mwave/Skusearch.hmx?scriteria=ba24443 has a rebate too, final price: $68
Ah, the IP35-E is being discontinued and replaced with the -V, rumors have it.
http://forum.uabit.com/showthread.php?t=130977
cliffs thanks to hokie "Per Furballi, here are the differences b/t the -E & -V:
E has...
-ICH9 with heat sink (no heat sink @ ICH7 for V)
-PWM heat sink (no PWM heat sink for V)
-Power module nearly identical to IP35 Pro (less robust power module for V)
-Four MOSFET driven fan headers (three for V)
-Twelve USB 2.0 ports (eight for V)
-Molex AUX power plug for GPU (no molex AUX for V)
IP35V adds 1394a and a CMOS reset switch."
Personally, I find the -V too gimped to make it worth the money.
I would either hop on the IP35 vanilla deal, wait, hope NewEgg restocks the -E and you can actually order one before it vanishes again, or go with a different manufacturer.
Hmmm...I just found Gigabyte GA-P35-DS3L. So it's either this or the V version
Newegg has deactivated that item, the IP35-E.
hey im in the exact same position as you,Im looking for a mb besides the ip35 but not sure which is the next best at about the same price range.
what's the difference between the vanilla and the -E ?? :confused::confused::confused: so many models.
If you think abit having 4 models is bad Gigabyte & Asus have more ...
The standard IP35 has ICH9R instead of ICH9 on the -E.
It also adds firewire & different chipset cooling.
I got my MSI Neo2-FR from newegg open box for under $70 IIRC.
Personally, I'd spend the extra $5 (AR) for the IP35 vanilla over the DS3L. I can't complain at all about the IP35-E build I had and can complain (slightly) about my DS2R mATX build. While I understand I'm not comparing apples to apples, I still think Abit did a good job this time around.
What other hardware are you using it with, how well does it OC & how well is it faring overall?
I've been curious about that board for a while, finally went with the vanilla IP35 over the Neo2-FR myself, since that's a little more proven.
E6550 cpu and 2GB OCZ platinum ram. It oc'ed easily to 400fsb but i need a better cooler to go higher i believe. I tried 433 and it froze as it was loading windows so it's either ram or cooling. I currently use a Vortex TX but I have a Freezer 7 Pro on the way.
EDIT: I think i may grab an IP35-E and see if it's not the mobo holding me back. I heard the early revisions of this mobo don't OC as well as the later ones.
I haven't heard anything about the MSI at all, keep us updated as MSI boards are cheaper than others $$$ with the same chipset.
