gwai lo said:chips aren't guaranteed to be able to oc a certain amount...
http://www.cpudatabase.com/CPUdb/Showdata.cfm might help
Buckus said:If you do get it to run faster, good for you, but you shouldn't *expect* to be able to overclock any one chip to a certain level just because the ub3er l337 Rob on the [H] Forum says he can get his 1.7 P4 to 4 Ghz "Without even a heatsink and fan! Seriously!"
Sir-Fragalot said:There are some instances of the 2.4C going into the 3.4+ range, but that isn't the norm. 4GHz isn't going to happen without phase change cooling.
ryuji said:so ~3.2-3.6 is the norm... still a improvment over 2.6 ghtz athlon-xpesp at that fsb maybe with some luck ill get 300 fsb
ryuji said:i plan on getting either a xp-90 or a xp-120.. havent decided which yet found xp-120 for $50 tho![]()
im gonna see how far stock volts and sink gets me.. ill go from there![]()
Jonsey said:3.2 to 3.6 is not the norm. My 2.4 would only do 3.1, and many people's wouldn't even do that well. You're setting yourself up for disappointment with such high expectations.
PureBooYah said:i would say 3.2-3.3 is the norm, the good ones did 3.4+. I wouldn't say many people's wouldn't even do 3.1, i would instead say many people stopped at 250fsb, 3.0ghz for a nice easy safe oc, they never tried higher. I would say yours is an odd bad egg, since most 2.4c's i've seen and owned can do 3.2ghz+
thats what rma is for.. id be happy with 3.3 but 3.6 would be muahahahaha!Jonsey said:Maybe that's just my inner pessimist coming through.![]()
It just sucks to see someone buy a CPU based on what they think it should overclock to, and then being disappointed.
ryuji said:thats what rma is for.. id be happy with 3.3 but 3.6 would be muahahahaha!
i know not to expect more then 800-1000 mhtz but 2.4c's are supposively special in that aspect
DCshoeCoUSA said:i have a 2.4c and i hit 3.0ghz with pc2700 ram, no problems. havent tried any higher... probably wont until i get better ram.
Sir-Fragalot said:I had a 2.4C that wouldn't go past 2.6GHz.Believe me at the time my system had everything else it would have needed to go faster than that. The CPU just wouldn't do it.
ScHpAnKy said:This is a bit off-topic, but why did you go LGA775?
acascianelli said:funny that you say that, when i first built my pc i had my 2.4c in my ic7-g and no matter what i did it would not go past 2.7ghz. i updated the bios and now im at 3.4ghz![]()
Sigworthy material at it's best.Buckus said:If you do get it to run faster, good for you, but you shouldn't *expect* to be able to overclock any one chip to a certain level just because the ub3er l337 Rob on the [H] Forum says he can get his 1.7 P4 to 4 Ghz "Without even a heatsink and fan! Seriously!"
ryuji said:first try overclocking it seems to get me 3 ghtz (250x12) at 1.575v
whats your settings... ill plug em in and give it a shot im running it in a ic7 my friend loaned me because my mobo came defective the msi board got 3 ghtz also but it seemed the ich5 was screwed up unless you consider 7 fps in ut2k4 normalMemoryInAGarden said:That's very, very normal. I'd say you'll top out 3.3-3.4 depending on PAT settings and voltage
