Well, I've started having some issues with my rig lately. It all started when I switched to the latest 175 nvidia drivers. During games of company of heroes, my computer will just click off.
My system is...
E6600 @ 3.0GHz +.0875v over stock
Antec True Power 850W (~6 months old)
DFI Infinity P965 Dark motherboard
(4x1gb) 4GB Crucial Ballistix PC2-1000
Watercooled system (CPU, NB, SB, GPU)
eVGA 8800GTS
I've never had this issue before where the system just clicks off. I run very low voltages on most all my components because the system seemed to get unstable with higher voltages. My ram was running at 2.0v (2.3v stock) but I run my system on a low ram strap because I'm running 4 sticks, it gets unstable with the higher straps. my northbridge was running at stock voltage (1.25v) as is all my other components except the cpu which is +.0875v over stock. I went ahead and clicked everything up a notch and it didn't reset for a few hours of gameplay, however the next day it clicked off on me again. I've since upped voltages further but haven't really tested it.
From my experience, an instant shutdown is usually a power supply issue, however my system is most likely not utilizing even 50% of my PSU's total output (my waterpump is separate AC), so cap drain shouldn't really be an issue for me since the PSU is still fairly new.
The odd thing is all this started with the 175 drivers. I rolled back to the 174, still didn't fix it, rolled back to the older 169 (?) drivers, and that is where it's seemed to be most stable, but I seem to think this is just a coincidence.. I've run out of solutions and I need some of you experienced guys to chime in. Also, I might add that I also considered a heat issue, however the moment it resets itself I go right into my bios to check temps to see if something overheated, and the hottest component is my northbridge @ 45c... so I don't think that heat is the problem here.
My video card is overclocked normally @ 700MHz core / 1800MHz memory. It will run 720/915, but I keep it a little conservative. I never see artifacts... I've run the card with the clock at stock speeds and it seems to have no effect on the reset issue.
Please, let me know what you guys think, I'd really appreciate it.
My system is...
eVGA 8800GTS
