This is my first post and opportunity to get into water cooling.
My 1st Question: Is a LARGE Passive Radiator better than a smaller Active/Fan Radiator?
Please keep in mind I would to cool an AMD 4800+X2 & (2) 7800 GTX 512MB in SLI mode.
I know that I will have to add 2 more waterblocks for the gfx cards... with this information in mind - please take a look at the following 3 Stacker Ready2Go setups from AlphaCool.
Original Stacker w/PASSIVE SIDE:
http://www.alphacool.de/xt/product_...e/xt/product_info.php?products_id=3581&cPath=
Technical data:
Case: Coolermaster Stacker "Server"
CPU cooler: NexXxoS XP Rev.2
Mountings AMD XP, AMD 64 and Opteron, Intel 478 and Socket 775
Radiator: NexXxoS Pro II
Fan: 2x Alphacool 120x120x25mm 1200rpm
Pump: AGB Eheim 600 Station 230V
Hose: 10mm
Connections: fittings
1st Gen Stacker w/ (3) FAN+Active TOP: http://www.alphacool.de/xt/product_info.php?products_id=2190&cPath=
Technical data:
Case: Coolermaster Stacker Black
Radiator: NexXxoS Pro III
Fan: 3x Alphacool 120x120x25mm 1200rpm
Hose: 10mm
Bottom line...what would you buy and why?
Thank you very much!
-Malt
*LINKS FIXED*
Technical data:
Hose: 10mm
Technical data:
Hose: 10mm
-Malt
*LINKS FIXED*
