Akasa in the US??
bamafamily
Hey All,
I have went over the reviews here and at trusted reviews and like the Akasa 460W V2 supply..Any place to get them in the states???
I want 450W+, dual rails, 24p connector (+20p adapter) at a decent price...
Taigan looked good but lacked the dual rails...
advice??..thx
If you got that Tagan for the system in your sig, it won't even break a sweat. XP-M processor with a 9600Pro would run fine on a Tagan 330. My Tagan-480 is pushing my system fine with almost every single possible MHz squeezed out of CPU/video that I could on conservative cooling. Upped voltages, 30% cpu oc, 70% vid core oc, and some ram oc as well.
Yours is the type system I am moving to in the summer/fall and I wanted to make sure I had a "semi future" proof supply..
thx
The tagan 480W is good for single cpu systems.
My 480W tagan is stressed though to the max.
I am running 2 x 1.6LV xeons @ 3.0ghz.
I suggest a stronger PSU if you plan on using Duals. Something with like 36 or maybe 60 amps on the 12v line
