I need some answers and advice about my setup because either I'm doing something really wrong or the people I'm talking to are full of it.
My system is as follows:
Motherboard: ASUS P5N32-E SLI
CPU: Intel Core 2 Duo E6400 Overclocked from 266x8 to 333x8.
Video Card: BFG GeForce GTS-250
Case: Coolermaster CM690
Hard Drives:
2 Seagate 1.5 TB 7200.11
1 Seagate 500 GB 7200.10
1 Seagate 400 GB 7200.10
I have the following in my case for cooling:
1 120mm intake in the front running at approx. 1962 RPM.
2 120mm exhaust on top of the case. Both running as approx. 1875 RPM.
1 120mm exhaust in the rear, running at 1500 RPM (This is a 2000 RPM fan, but the motherboard doesn't seem to run this fan at full speed)
1 120mm intake on the side panel running at 1300 RPM for cooling the expansion bays.
A Coolermaster Hyper TX3 cooling the CPU. The fan it comes with runs at 2800 RPM and blows towards the back of the case where the rear exhaust is. I have added a second fan to the cooler which is blowing in the same direction and runs at about 1800 RPM.
I have tried adding another 120MM intake to the side panel but it seems to intefere with the CPU cooler and actually causes the CPU temperature to rise. Does this sound correct?
The following are the temperatures I am getting inside the case:
The video card idles at 48 degrees.
All 4 hard drives idle at around 40 to 41 degrees.
I'm not sure what the cpu idles at right now. I am running Prime95 at the moment and with the CPU overclocked, both cores jump between 62 and 68 degrees at full load according to Core Temp.
From what I've read on the internet in multiple places all of these temperatures should be lower for my setup. I cannot seem to find a straight answer anywhere on whether or not my temps are too high or fine for my setup. Am I wasting my time worring about this or do I have something to worry about?
Hard Drives:
