Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
This might be a stupid question but when you do a dry pressure test with air, can you use a co2 cartridge instead? Will it damage anything if I open the valve a quarter?
Almost no one does a dry pressure test. Typically people will run the pump on a separate power supply with the main system powered off, put paper towels underneath the connections, and let it run for a day and see if there are any leaks.
The maximum pressure put out by a 355 pump is about 8 PSI. Two of those can do 16 PSI, and that's the highest pressure you will ever see in a system. A CO2 cartridge is 853 PSI... I would say you are running a high risk of damaging something by using one. Just do the one day leakage test.
If the pressure is too high you'll blow out a seal/o-ring/gasket. Doesn't matter what the gas is (assuming not caustic), too much pressure will find a way out.
I have ran a vacuum test successfully.before however.
As others have said, this is a quick way to damage a loop.
I've seen people do the blow test, where they'll blow into a hose attached to the loop and see if it holds pressure against their lungs. Probably good enough to see if you left any fittings loose or disconnected, but not likely to find pinhole leaks due to a cut o-ring or the like.
I tried to nitrogen test a radiator to less than 100psi.(was considering using for 134a to make a phase change loop) and it blew the rad up like a balloon. All the copper and fins swelled...so yea, don't do that. Lol
Any reasonable positive pressure to do any real dry testing will be too much or you need some real good equipment to measure very small pressure decay off say 20psi or so.
