madacoustiks
- Mar 1, 2008
I've got an IP35 Pro with a WD6400AAKS and both the JMicron and the Intel controllers are set to AHCI mode. I think all of the SATA devices are on the Intel controller. I just did a clean install and installed the Intel Chipset drivers. When I went to install the Intel Matrix Storage Manager my computer won't log in. It locks up at the login screen. I don't want to do RAID, I'm just trying to figure out how to enable NCQ for sure. I've done a ton of google searching and everything seems to be about switching from IDE to AHCI mode. I thought by installing the Intel software, I might be able to figure out where NCQ mode is. I've got Vista x64 BTW.
I previously had installed Vista in IDE mode and was able to switch it over to AHCI mode, but when I had this problem with the Intel RAID software, I thought that switch was part of the problem so I did a clean install with BIOS set to AHCI.
I don't understand why I can't find the option to enable NCQ. It seems like it's under Storage Controllers in Device Manager for nForce chipsets (from google searches), but I can't find it for the ICH9R. So my questions are:
1. Does anybody know why the Intel Matrix Storage Manager locks up my comp?
2. Where is the option for NCQ in Vista?
