AGP voltages and speeds?
bhw752k
Hi, I'm wondering if there's any experts here on "vintage" -ish hardware...
I've got an older system with a Celeron 366, ASUS P2L97 motherboard, and 256 MB of PC100 (running at 66 MHz). When I try to pop in my Voodoo 3 3000 AGP, the system hangs shortly after Windows boots. The video card is VERY hot. I used the Voodoo 3 on a similar system (which I no longer have) long ago and it was fine - I've also tested it out on an Athlon 1800+ based computer and it was fine.
The Celeron system works fine with an ATI Rage IIc, or Rage Pro.
I'd really prefer to use the Voodoo 3 because it supports glide and 366 MHz era games. Also, my two crappy ATI cards are 4MB so their 2D resolution support isn't so good.
I read about a problem with the P2L97 Revision 1.x (among others) where the AGP slot isn't given enough voltage - so "high end" AGP cards like the Voodoo 3, TNT, and GeForce1 don't work properly. The "fix" involves soldering a wire to the back. However, my motherboard clearly has "Revision 2.05" printed on it. So I'm not sure what's going on there.
I read about another fix, which is to force AGP 1x. I figure this might be a good thing to try, especailly since the Voodoo 3 AGP isn't really faster than the PCI version anyways. However, this setting doesn't appear to be in the BIOS. And getting it done in Powerstrip seems to be video card dependant (I think?). I can't boot into Windows 98SE with the Voodoo 3 for long enough to actually run Powerstrip and change the setting, because it hangs too soon. Is there any way to change the AGP to 1x while using a Rage card, and keep it that way? I've read that VIA chipsets could install the AGP driver in non-turbo mode to do this - but my chipset is an Intel 440LX.
Oh, and the Voodoo gets so hot that even putting a gigantic room fan over it won't prevent the system from hanging - I'm impressed that it hangs rather than fries. Oh, and I already have the lastest motherboard BIOS.
Thanks for reading, and for any advice! :)
Wow...I'm trying to do something similar with a computer like that to run my old games on. My problem was related to disabling the onboard video (it seems the jumper doesn't work on the motherboard). I tried to put in a PCI Rage XL vid card, but it didn't play nicely with the supposedly disabled onboard ATI chip.
Also it doesn't seem like DOS games like Win98 sound card drivers ;).
The good ol' Celeron 366. Monkey Island and X-Wing live again :D.
