Agp voltage on STP800
Lag-User
hi
i have a ati 9600xt 128mb adn i have a problem.
I get AGp off i serach on the net and the problem seems to be the low voltage on AGP
my mobo(chaintechSTP800)doint have voltage control so is there any program that i can
use to do that?
i search on the net but nothing seems to be around for that mobo
Thnx in adance
Stefanos
AGP voltage is a factor of what mode your using. Here's an off the top of my head reference (might not be accurate...check it out).
1X/2X - 3.3V
4X - 1.5V
8X - .8V
The AGP slots is slotted differently for different voltage also.
i dont know about that voltage you told me about but i mean the voltage that in other mobos are in bios and you have to choose betwin 1,5v and 1,7v
mine works in 1,5v and i need to change it to 1,7v
so youy knwo any utilitis that work with that mobo?
thnx
stefanos
Yeah, I have no idea how to raise the AGP voltage is your motherboard doesn't allow you to change it. I haven't seen any programs out there, but that doesn't mean they don't exist.
