MaXimus666 said:what i know is, you should set the aperture size to half your RAM size always,
so you shouldd do 256 since that's the max amount in the BIOS i gues.
I have mine set to 256 MB
DejaWiz said:No, there is no respective setting for PCIe, since the I/O busses are completely different.
Well since this thread is back up and I just did a search for aperture sizes because I have been wondering forever, I'd like to know what videocard 256MB is most efficient for?BattleMaster said:Set it to 256MB. I've done some performance testing and that seems to be the optimal setting. In lieu of that, 128MB isn't bad either.
