- Oct 29, 2000
Has anyone used one of these?
I picked one up as I found it locally at Microcenter, and it was cheap. I want it to hold me over until the Corsair Link units come out.
I have a small issue with it, I was hoping someone might have a solution for.
It ramps up the case fans when the measurements get hot - as it should - but th eproblem is, it doesnt ramp them up, until it hits the alarm temperature, which means the unit starts beeping.
I wanted this thing to just turn up the fans when needed, and turn them back down when not needed, not beep at me. If I set the alarms higher, the fans just stay at the lowest speed the whole time.
The unit does not have a way to turn off the audible alarm (at least not documented in the manual).
Can I just locate the sound emitting component on the board and cover/crush/cut/destroy it somehow? Does anyone know what that component looks like?
This is what the back of the board looks like:
Much obliged,
Matt
Much obliged,
Matt
