ralphie1313
- Jan 15, 2019
Hey guys, is it worth buying an Asus ROG Crosshair X670E Extreme REFURBISHED.. For 669$ from NewEgg? Mostly all positive reviews, but what do you guys think? Thanks!
690-790? Is that intel? I will only go amdIf you need a specific feature yes, look at 690 vs 790 platforms the only difference is a TB port I believe. I went 690 and am satisfied. DD5 is more affordable now not a deal breaker. I went from X99/5820K to 12700K and after the novelty wore off the only diff is in higher min FPS.
My days of number crunching are over, retired analytical center director with a extensive SEM and XRD background.
