Advice on upgrades please.
Kaidenn
So with the holidays around I'm looking to get some new parts for my rig. Not to sure what stuff is considered an upgrade so I'll just leave my specs and see what you guys have to say. Budget is around 500-600$
CPU: I5 750 @3.8ghz
GPU: XFX 7850 2GB (Just bought an R9 290 so this doesn't really count)
RAM: 8GB GSKILL
Hard Drive: Hitachi 465GB
Mother Board: GIGABYTE P55M-UD2
Power Supply: 700W
Also If anyone has some suggestions on a good case that would be helpfull cuz the one i currently have is way to small. Thanks in advance for the help.
what is the speed of ram you have? and its timings cpu-z can help you find this info out.
i7 3570/3770k and motherboard to go with it. Asus Z87 as example
Case there is many to choose from that are good so it just really depends.
I would probably go with cpu-motherboard upgrade, add an SSD then get whatever case you have left in your budget. Arc Midi R2 is a nice one, Source 210 ELITE NZXT is another, Cougar makes some decent ones that are not that pricey, Enermax iVektor midtower quite decent, INWIN G7 is a hell of a case, EVGA Hadron is another but is pricey enough.
There is many choices out there and everyone has their own thoughts on what makes one a good case, the iVektor is interesting as it does have a ton of room for the size of case it is, as does the Hadron, you want uber room and fantastic cooling then well Air540 is the one to beat :p
First and foremost: What PSU do you have? From what I've seen, any PSU rated at 700W tends to be range from shitty to mediocre. Considering that you just bought a rather power hungry video card, you should absolute sure that your PSU is of good enough quality to power that card. So again, what PSU do you have?
SOme additional questions:
6) Will you be overclocking?
8) When do you plan on buying the upgrades?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? UEFI? etc.
As for cases, I recommend the following cases:
$50 - Corsair Carbide Series 200R ATX Case
$75 - Corsair Carbide Series 300R ATX Case
$90 - Corsair Carbide Series 400R ATX Case
$100 - NZXT Phantom PHAN-001BK White Full Tower ATX Case
$100 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$110 - Antec 1100 ATX Case
$110 - Corsair Vengeance Series C70 Arctic White ATX Case
$120 - Corsair Vengeance Series C70 Gunmetal Black ATX Case
$125 - Corsair Carbide Series 500R ATX Case
$130 - NZXT Phantom 530 Black Full Tower ATX Case
$144 - Silverstone RV03B-W ATX case
$144 - Silverstone RV03B-WA ATX case
$115 - Corsair Graphite Series 600TM ATX Case
$160 - Corsair Obsidian Series 750D ATX Case
$160 - Corsair Special Edition White Graphite Series 600T ATX Case
$170 - Corsair Obsidian Series 650D ATX Case
$170 - NZXT Phantom 630 Gunmetal Full Tower ATX Case
$170 - NZXT Phantom 630 White Full Tower ATX Case
$230 - Silverstone FT02B-USB3.0 ATX Case
$250 - Silverstone FT02S-W-USB3.0 ATX Case
$245 - Corsair Obsidian Series 800D CC800DW ATX Case
