Advice on new gaming PC build
MetalX
Ok first off if this is the wrong forum please accept my humble apology. I haven't visited [H] much the last year or so. Also I've been completely out of the PC building scene the last few years since I got married but now that the evil bitch is gone it's time to build one. What do you guys think of the one below? The only thing I'm not sure of is the RAM because back in my day you just got yourself some decent DDR and was good to go since AMD chips weren't really effected by memory bandwidth. Thanks for any advice.
I love the ram. I have 4 sticks of it. Good stuff.
And you're right, it's in the wrong section. It should be in General Hardware.
ROFL haha sorry, man this statement just made me laugh. Anyways, what's your budget on this build and what will be the primary use of this PC. Also, what size monitor do you have?
For only a few dollars more, you could get 4GB of DDR2 800 RAM. Yes, you'll lose the $30 mail-in rebate, but, in terms of immediate benefit, you get more memory to play with.
So, how about answering a few (more) questions for us?
- How much, at most, are you willing to spend on these upgrades?
- What you are reusing for this system?
- Do you plan on overclocking?
- How long do you want these upgrades to last?
All I need is the following:
CPU
RAM
MOBO
PSU
GPU
$700 max for everything would be nice. I certainly plan to overclock. You can take the geek out of [H] but you can't take the [H] out of the geek.
This PC will be used mostly for gaming as indicated in the subject title. My monitor is a 19" NEC 90GX2 LCD with a 1280x1024 native resolution at 75hz.
Again I've been completely out of the PC building scene for a few years so I'd like to stick with WinXP if possible. Is Vista necessary these days to play the latest games? Will 4GB of RAM over 2GB be beneficial in gaming? Also are Core2Duos memory bandwidth whores like Pentium 4s used to be?
The PC in my sig is what this will be replacing. Thanks for the replies so far, you guys are great.
EDIT: These are the games I'm wanting to try:
Oblivion
Fallout 3
Call of Duty 4
Red Alert 3
Vista is not neccessary if you don't care for DX10 graphics. If you have a legal transfereable copy of XP and don't mind only being able to use 3 to 3.5GB of RAM out of 4GB RAM due to 32bit limitations, then stick with XP. If not, then go with Vista Home Premium 64bit. 4GB of RAM will not be directly beneficial in gaming. However 4GB of RAM would allow you to have more apps running in background. In other words, 4GB of RAM is more beneficial to the system as a whole, not for gaming.
C2Ds are not memoery bandwidth whores. In fact quite the opposite. Core 2 Duos do not gain a single ounce of real world performance with higher speed RAM. Technically, all you need is a 1:1 FSB:DRAM ratio and you'll be set. Some math:
Stated FSB/4 = Actual FSB
Actual FSB x 4 = Stated FSB
Multiplier x Actual FSB = CPU Speed
1:1 Ratio: 2 x Actual FSB = RAM Speed
1:1 Ratio: FSB = 1/2 RAM speed
Note that C2D systems don't see a performance increase with any ratio higher than 1:1
E7200:
Multi x Actual FSB, RAM Speed = Clock Speed
9.5 × 266Mhz = 2.53Ghz, DDR2-533 <<== Stock speeds
9.5 × 333Mhz = 3.16Ghz, DDR2-667 <<== Easy OC
9.5 × 400Mhz = 3.8Ghz, DDR2-800 <<== Excellent OC
E8400:
9 x 333Mhz, DDR2 667 RAM = 3.0Ghz <== Stock Speeds
9 x 400Mhz, DDR2 800 RAM = 3.6Ghz <== Easy OC
9 x 450Mhz, DDR2 900 RAM = 4.0Ghz <== Excellent OC
9 x 500Mhz, DDR2 1000 RAM = 4.5Ghz <== If you're EXTREMELY lucky
Anyway, here's a prelim build for ya:
Intel Core 2 Duo E7200 CPU - $120
Gigabyte GA-EP45-UD3P Intel P45 Motherboard - $137
G.Skill F2-6400CL5D-4GBPQ 2 x 2GB DDR2 800 RAM - $50
PNY VCGGTX260XPB GeForce GTX 260 896MB PCI-E Video Card - $240
Antec NeoPower 650 650W Modular PSU - $75
Xigmatek HDT-S1283 120mm Rifle HSF - $37 & Retention Bracket - $7
Total: $666 :)D) Plus tax and shipping
If you can spare another $11 out of the $700 budget, you can squeeze in the E8400 for $165. A E8400 at 3.6Ghz would outperform a E7200 at 3.8Ghz....
The GTX260 is bit overkill for 1280x1024 gaming but at least you'll never have to worry about lack of GPU power.
You could save the money for the E8400 by swapping the GTX260 to the SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 but dish out the extra 11$ and get both. you'll get it back in the rebates anyways ^ ^. you could also swap for the 4850 and get the antec 300 case to complement the PSU with a 30$ instant saving.
all in all up to you but that preliminary build is 5stars.
P.S. glad to have you back. ;)
P5Q pro $119
e8400 $165
antec 650 psu $75
Rifle cooler $37
Retention bracket $7
arctic silver thermal compound $6
OCZ Platinum Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) $64
total before shipping and tax$628.92
i changed the memory, mobo, and combined what i felt to be the best of other suggestions out there. I also added the often forgotten thermal compound because for a good OC it's very very very important and the cooler listed comes with the white crap that is basically useless for OCing
As an FYI, getting the P5Q Pro and the E8400 together gives you a $30 instant rebate as part of their bundle deal (though you'll gain the same rebate by pairing the motherboard and RAM together as well -- but you can't combine the three deals to gain even more savings).
The TIM that comes with the Xigmatek HDT-S1283 is good enough that you don't really need the Arctic Silver 5. But if you really want "better stuff," buy some thermal compound that doesn't require any curing time, like the Arctic Cooling MX-2.
Agreed. 200hrs is beyond ridiculous
UD3P vs P5Q Pro --- What is the advantage of each? I've noticed some people are split on which to go with. As far as CPU I'm pretty much sold on the E8400, but the rest is still up in the air. Thank you for all the help guys.
Here's the NewEgg comparison page, but it doesn't give you a full picture of each board's strength. Both should work just fine for your needs.
However, one advantage the P5Q Pro does have over the UD3P is price: you can get the E8400 and the P5Q Pro together and instantly save $30.
The UD3P has a bit more features than the P5QPro such as more USB ports, 8 vs 6, Dual Gigabit Lan, Optical out and UD3P has support for up to 16GB Ram vs 8GB Ram. But, the Combo deal that tiraides mentioned is a deal for the E8400CPU + Asus P5QPro mobo for $255 is cheap. It's like the Asus P5QPro mobo is $90 with this combo. If you get the UD3P mobo and a E8400 cpu it will be $302 you pay upfront.
