advice on new build
htapocysp
Approximate Purchase Date: within days
Budget Range: ~2000
System Usage from Most to Least Important: gaming
Parts Not Required: mouse
Preferred Website(s) for Parts: newegg.com (used to be amazon too but they tax now)
Country: USA
Parts Preferences: I think this is where i put my build im looking at.
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
ASUS VS248H-P Black 24" HDMI LED Backlight Widescreen LCD Monitor
Linksys AE3000 USB 2.0 Dual-Band Wireless-N Adapter with 3 x 3 Antenna
XFX Double D FX-785A-CDFC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
CORSAIR Gaming Series GS800 800W
RAZER Black USB Wired BlackWidow Ultimate Mechanical Gaming Keyboard
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8
ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i5-3570K Ivy Bridge 3.4GHz
COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case Fan x2
SAMSUNG 830 Series MZ-7PC256D/AM 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD) Desktop Upgrade Kit
Thermaltake Chaser MK-I (VN300M1W2N) Black SECC ATX Full Tower Computer Case
Overclocking: Yes but not right away
SLI or Crossfire: Not yet
Monitor Resolution: 1080
Additional Comments: Looking to see what you guys think.
That PSU is one of the worst Corsair PSUs ever made. 150W overkill for even two 7850s. The TX650 V2, NZXT Hale82 650W, or the Silverstone Strider 650W PSU will be just fine. Unless you're very fond of the size and the looks of that case, don't get it. Full Tower is only needed if you run a custom loop, and even then, some Mid-Towers support it just fine. What do you need in that MOBO that cheaper motherboards lack?
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
What games are you playing? At what level of visual quality?
How far is your system going to be from your primary modem/router area?
Do you already have a hard drive on hand for storage/backup?
