Hello, first time I've actually posted a thread here. Usually I just lurk to get a second opinion on a list I've already made. Anyway, I'm currently trying to upgrade one computer that has a Q6600 with a SSD (only 40 to 64GB), re-do my HTPC so I can use it to play certain games on it (mostly single player that I'd rather not sit at my desk for and can sell off my consoles), use it as a functioning computer at times, and finally build another computer.
Will be using this computer for gaming, photoshop, 3D modeling, and video editing
The cheaper the better but I currently don't have a budget
I live in NYC - I have fairly easy access to a Micro Center
HTPC: CPU, Motherboard, GPU, RAM, and PSU
MAIN Computer: CPU, Motherboard, RAM, Cooling, Monitor, and Speakers
Corsair AX850 Power Supply, PowerCooler HD 6950 x2, Intel X-25M G2 160 SSD, Asus Sonar Essence ST(X) and Coolermaster HAF-X case
Also have a HTPC case, power supply (only 430W so most likely of no use for these upgrades), Blu-ray drive, and enough hard drives
6) Will you be overclocking?
Yes.
I currently have 3x 23" monitors at 1920x1080 (or 5760x1080 in EyeFinity) but am looking to "downgrade" to either a 30" (2560x1600) or 27" (2560 x 1440) for more space and so it's easier to drive.
Within the month - most likely sooner.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, SATA 6Gb/s, eSATA, Onboard Video (in case graphics crap out on me), Xfire (obviously)
Windows 7 Professional 64-bit
Now, so far I have come up with these:
HTPC:
CPU: Intel i5 2500K
MOBO: Gigabyte GA-Z68MA-D2H-B3 (http://www.microcenter.com/single_product_results.phtml?product_id=0364087)
GPU: MSI N560GTX-Ti Twin Frozr II (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127608)
Went with nvidia purely because of the option to use Physx. I'm a huge Batman fan - I need to have my cape look prettier
RAM: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416)
PSU: SeaSonic M12II 620 Bronze (http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095)
I plan to use the stock cooler for now because of possible clearance issues within the case. If anyone has any low-profile options that cools well - I'm all ears.
The only two concerns I have are the PSU and motherboard. I'm looking to waste as little money as possible on these while wanting a modular PSU so I can not have wires all over the place in a rather small case and also the motherboard only have 2 fan headers. But, my only other choice from MC ($60 combo) seems to be the Asrock (from what I've read here - I should stay away from).
If there's any justifiable reason that I would require a higher end motherboard please feel free to point it out.
Main Computer:
CPU: Intel i7 2600K (or 2700K if MC offers it instead by the time of purchase)
MOBO: GA-Z68X-UD3H-B3 (http://www.microcenter.com/single_product_results.phtml?product_id=0364085)
Not sure if this will fit my two graphics cards and the sound card?
Now, that I've considered it - it doesn't have nearly enough fan headers for the amount of fans I have in my case (currently 8)
Also, I recall the Intel LAN chip was always preferred over Realtek. Is this still the case?
RAM: G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 x2(http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416)
SSD: Crucial M4 128GB or 256GB SSD (Depending on my situation at the time)
COOLING: Corsair Hydro Series H100 (I have a Silver Arrow laying around here somewhere but I want to go for something cleaner looking and I've despised having to remount the SA every time I've wanted to access the memory)
Monitor: Dell U3011, Samsung SA850 27", HP ZR30W, or ZR2740w (Currently undecided)
Finally - I plan to purchase a Crucial M4 64GB to throw into the Q6600 computer I have laying around (or I may put that into the HTPC and put the Intel 40gb in the Q6600).
One thing to note: I've been known to foolishly throw money at computer parts just so I can have matching colors. Which, is a reason I've steered clear of motherboards with the blue/white color themes (Since most of my other parts are black/gray/red). So, if there's no drastic price difference - I'd be willing to spend some more money on keeping my colors safe
Thanks in advance (and apologies for the long post!) ...
Yes.
HTPC:
CPU: Intel i5 2500K
Main Computer:
