Advice on first build
chevelle4life
I need some advice on anew build. My budget is 750 this is $ 686.99. The shipping and taxes I will add on later. Are the items I selected good for $686.99? ANy suggestions
Links are on the reply
I agree with the above, if you can afford it. I'd also recommend getting at least a 6600GT video card. If you can't afford to upgrade much past where you are, I'd at least recommend a better mobo. You can get an Abit AV8 for around $115 or an MSI NEO2-F board for around $98. If you're not into overclocking (which the RAM suggests), then either of those should work fine and be better then that ATI board... ;)
I agree, you really should go for a DFI or MSI motherboard because they are made with quality for their price.
...Dan
