Advice on DAW build
icethepuck
1) What will you be doing with this PC?
I will be using it as a digital audio workstation (electronic music), using only software. VSTs, Midi, Audio Samples, etc... Some gaming, light internet, music, and all that jazz.
$1000 CAD shipping included. I can also buy parts in person from www.infonec.com, so shipping may not be an issue.
3) Where do you live?
Toronto Ontario, Canada.
4) What exact parts do you need for that budget?
Pretty much everything, except case and CD-ROM.
5) If reusing any parts, what parts will you be reusing?
I've decided to reuse my case, CD-ROM drive.
6) Will you be overclocking?
Nope.
Already have 22" 1680x1050.
Within the next week or two.
9) What features do you need in a motherboard?
Not sure, exactly.
10) Do you already have a legit and reusable/transferable OS key/license?
No, but I don't want that factored in the price.
Running 64-bit Vista.
BUILD:
Processor - $274
Mobo - $174
Ram - $114
PSU - $105
Hardrive - $90
Graphics $240
Total = $974 Before tax.
Suggestions ?
Wait so you're gonna need a new monitor as well?
If so, is that factored into the $1000 budget?
You can do a whole lot better for the cash.
Ditch that crappy OCZ PSU with this significantly better quality PSU:
$100 CAD - PC P&C Silencer 610W PSU.
CPU and mobo wise, I recommend the following since they have a bit more of an upgrade path than Intel's socket 775 and offers comparable performance:
$240 CAD - AMD Phenom II X4 920 Black Edition CPU
$140 CAD - Gigabyte GA-MA790X-UD4P AMD AM3 790X Motherboard
RAM wise. that OCZ set is a total waste of money. This RAM set will perform about the same for half the price:
$55 CAD - G.Skill F2-6400CL5D-4GBPQ 2 x 2GB DDR2 800 RAM
GPU wise, I recommend getting the eVGA GTX 260 since A) its performance is the same as the HD4870 and B) it comes with a lifetime warranty once you register it:
$$235 CAD - eVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB PCI-E Video Card
i don't see a sound card listed there?!
you will definitely want a DAW caliber PCI card for your audio
that is unless you enjoy high latency and buffer underruns
i would definitely recommend purchasing a good sound card for your DAW before even thinking about a high end graphics card
m-audio's delta 44 should work pretty well for your needs
