Advice on comp purchase needed
radiophed
Hey,
Gaming and Photoshop / Illustrator work
My budget is $600 for CPU / MB / RAM
Seattle, WA.
I have quality parts for HDDs and DVD/RW drives, Video Card is currently 560ti 448 core (Waiting on 700 series)
CORSAIR HX Series CMPSU-520HX 520W ATX12V v2.2, MSI N560GTX-Ti 448 Twin Frozr III, COOLER MASTER Stacker 830 Evolution, Crucial RealSSD C300 256gb, Western Digital Raptor WD1500ADFD 150GB, SAMSUNG 20X DVD±R DVD Burner,
6) Will you be overclocking?
Not initially, but down the road I will be upgrading case to accommodate water cooling for CPU and most likely GPU.
1080p, 23" Dell IPS
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc
support for 2 high end GPUs down the road.
Windows 7 Ultimate 64bit
So with the current deals going on newegg I'm thinking of biting on a new setup
The following would cost $375.95 after all the stacking discounts and before the $40 in rebates.
Intel Core i5-3570K
ASRock Z77 Extreme4
CORSAIR XMS 8GB x 2 (16gb)
Arctic Silver 5 High-Density 3.5g
I currently own:
Q6600
abit awd9-max
6gb of ddr3
I'm looking for opinions on if I should upgrade or wait out better deals in the near future.
Thanks!
You should wait.
Intel's new and faster Haswell CPUs are due out in the June/July timeframe. So might as well wait the extra 1-2 months for that. I mean you're gonna have to get a completely new motherboard and RAM anyway so might as well get the latest. The Haswell CPUs will require a completely new motherboard socket that's not compatible with anything on the market today.
Not meaning to hijack, but just because I was thinking very similar build as OP.
Danny: The rationale for waiting, is it more to create a build with Haswell CPU & respective motherboard, or for price drop on Ivy Bridges and get a better bang for the buck?
I like waiting myself if, for a similar price point, I can semi-"future proof" by getting the next socket. But sometimes, waiting for new socket in order for existing items to drop in price, I find takes additional time past new socket coming out. So I wonder how long I can be patient for, haha.
600 fer cpu/mb/rams.. hmm
Know wat? I think used 1366 would be best bang fer buck (at this point in time)
hex-core xeon..er summin
