Advice on build
zohair
So all I have left to try to figure out is a new motherboard for my build:
So basic background info, going to put a core 2 duo processor in for now, maybe switch to a quad core later.
Don't need firewire, or raid, or SLI (though if they have them and for only a slight price increase why not?). Couple SATA slots are enough, don't need a ton.
More or less I'm looking for a board that won't crap out on me (had some bad luck in the past).
Thoughts on these boards?
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
Intel DQ35JOE Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3287199&body=MAIN#detailspecs
ABIT IP35 INTEL P35 CHIPSET ATX FORM FACTOR
http://www.mwave.com/mwave/viewspec.hmx?scriteria=BA23928&RSKU=BA23928
Not really sure how to go about picking one, any help regarding these board or suggestions of better ones would be great!
Thanks
Oh I guess I should mention this build is for gaming, using DDR2 800 ram, and probably don't want to spend over 150 ish (unless its a good deal for the price)!
Thanks
Hadn't looked at that Intel Board before, it seems the gigabyte is a bit cheaper though and fits your needs. Consider the IP35-E also instead of the IP35, it is a bit cheaper:
http://www.mwave.com/mwave/viewspec.hmx?scriteria=BA23929&RSKU=BA23929
and is more directly comparable to the DS3L. It has less SATA ports and no raid/heatpipe compared to the IP35, but it is comparable otherwise. It is known to be a pretty good overclocker, so it should fit what you need. Between it and the DS3L I think the two are rather close and whichever one you want to go with is a fine choice. Can't promise that the board won't go bad obviously, since anything can happen, but they are two of the more reliable brands and models for P35.
The DS3L has legacy ports in case you need them. The Abit IP35-E doesn't. Just an FYI.
