rhino.software
- May 30, 2008
hi everyone,
i have been spending the last week or so (with a £900 budget) looking and writing on a few forums inc this one for advice on a good gaming, inc low lag, large ips monitors and after all the advice was taken in i ended up with the following monitor...26" LG W2600HP of which i could get 2 of and best of all it uses the same panel as Nec's 26" which is a very good panel so im told but has an improved response time in games.
(please note im in the UK).
26" LG W2600HP
cheapest price found : £440 inc del
Average Input Lag / Crt............................. 6-8 ms
Module............................. LM300WQ5
Contrast Ratio............................. 1000:1 (5000:1 with DFC)
Pitch Size:............................. 0.287 mm
Brightness (cd/m2) ............................. 400 cd/m2
Response Time (ms)............................. 5ms GtG
NTSC Colour Gamut............................. 115%
W x H x D (including stand)............................. 602 x 563 x 270mm 10kg
spec : http://www.hardware.info/en-US/productdb/bGRkZpiVmJTKaMg/viewproductreviews/LG_W2600HPBN_W2600HPBN/
review : http://www.prad.de/en/monitore/review/2008/review-lg-w2600hp.html
the Hazro 26" has issues but has low lag i dont want to risk getting a dud...and the HP LP2475w is too much on the slow side as its only marginal faster than the nec 26"
after i compiled all the following info i wanted to see if anyone could advise me on which of the 3 30" panels would be best for ofice work and gaming because from what reviews i have seen they all seem good and have low lag for gaming.... especially the dell 30"
and also whether they are good at resolving the lower resolutions as i might want to play games like crysis at lower resolution, while using for day to day stuff like office word on default resolution.>>>>>>>>>>>this option is important for me.
basically the screen wouldnt be upgraded for a long time due to size .......
please can i have your thoughts......???????????
Dell 3008WFP 30" UltraSharp Flat Screen TFT Monitor
cheapest price found : ...............................£770 inc del New (auction site)
Dell 30" 3007WFP HC
cheapest price found : ...............................£450-900 inc del New (auction site)
Average Input Lag / Crt ................................11.5ms
Response Time (ms) ...................................8 ms G2G
Brightness (cd/m2) ......................................300 cd/m²
Contrast Ratio ................................................1000:1
Pitch Size: .......................................................0.250mm
NTSC Colour Gamut ......................................117%
W x H x D (including stand) ..........................690 x 469.7 x 200mm
award : HotHardware's Editor's Choice Award for innovation and excellence.
review : http://hothardware.com/Articles/Dell-UltraSharp-3007WFPHC--92-Color-Gamut-30-Inch-LCD/?page=1
30" Hazro HZ30W
cheapest price found : ....................................£864ish inc. del
(no scaler hardware)
Average Input Lag / Crt ....................................7.5ms
Response Time (ms) .....................................12ms G2G
Module ...............................................................LM300WQ3
Brightness (cd/m2) ...........................................300cd/m2
Contrast Ratio ....................................................1,000:1
Black Point (cd/m2) ............................................0.24
NTSC Colour Gamut ..........................................92%
review : http://www.tftcentral.co.uk/reviews/hazro_hz30w.htm
30" LG W3000HP
cheapest price found : ........................................£780ish inc.del
Average Input Lag / Crt .........................................15ms
Manufacturer ..........................................................LGD
Tech ..........................................................................S-IPS
Module ...................................................................LM300WQ5
Response Time (ms) ............................................5ms G2G
Contrast Ratio .........................................................1000:1 ...3000:1 (DCR)
Brightness (cd/m2) ...............................................370
NTSC Colour Gamut ...............................................115%
Pitch Size: ................................................................0.252 mm
W x H x D (including stand) ...................................700 x 630 x 270mm 12kg
spec : http://www.hardware.info/en-US/productdb/bGRkaZiWmJfKYcg/viewproduct/LG_W3000HBN/
www.hardware.info - Ultimate PC (10/13/2008)
A monster screen should go with a monster PC and that means a 30 inch ultra high resolution monitor. The LG W3000H-BN has an S-IPS panel with 2560x1600 pixels, a better than 900:1 contrast ratio, excellent reaction speed and input lag that is well within tolerances to enjoy a fast 3D game or high speed action scenes in your favourite movie. All this makes it a prime choice for the Ultimate system.
thankyou in advance to any advice.
26" LG W2600HP
Dell 30" 3007WFP HC
30" Hazro HZ30W
30" LG W3000HP
