Advice needed: Video card for this build
n0id
My 4+ year old system is finally showing age...Here's what i got so far, would love advice on a video card.
-- Gaming, all genres (FPS, mmorpg, RTS, etc..)
-- Everything included, i'd like to get a card thats $250 or less...but if the performance of a card is worth a little more compared to one that fits under that price point, I could make it work.
3) What I have so far:
Case: LianLi A05NB
Power supply: APEVIA ATX-AS680W-BL 680W ATX12V / EPS12V SLI Ready Power Supply
Motherboard: MSI P67A-6065 (B3)
Processor: Core i5 2500K
Memory: 8gb Corsair Vengeance DDR3 1600
Hard drive(s): re-used sata
DVD drive: re-used
Monitor: Acer H233H 1920x1080
Notes: I could really care less about multi-monitor gaming like eyefinity and stuff...really just looking for a very good compliment to the equipment above, and a big upgrade from my current video card, an Nvidia 8800 GTS 640mb 320bit GDDR3.
Sorry, didnt think it would have been relevant so I left it out.
I added to the OP, but i have:
You're looking at a new PSU. Apevia PSUs are just plain shitty and are very likely to harm hardware:
Apevia ATX-AS500W-BL
Apevia Warlock Power 900W
XQPack's Included 420W PSU
Aspire Beast 680W Power Supply
So I recommend these PSUs as a replacement:
$80 - Antec Truepower New TP-650 650W PSU
$100 - Antec Truepower New TP-750 750W PSU
If you get either of the above Antec PSUs, then I recommend either HD 6870 1GB or the HD 6950 1GB
i think the Nvidia 560 Ti might actually be the better performer in that price range, close anyways, should be an option
Thanks for the links! I must have been lucky, bought mine in 2007 and i've never had a problem with it. I'll keep it in mind.
What resolution do you play at? Oh sorry didn't see it up there. Get the MSI HAWK GTX 460. TALLON ATTACK. Its going for 200 usd
Actually I have that card, and yes it is bad ass, but I think for $30 more the 560GTX is the better deal at the $250 mark. But for $220 the Talon Attack is very good.
