I know you guys never get tired of helping people out with their upcoming rigs, and Im ordering my parts on Tuesday, so heres what Im looking at so far. Feel free to comment on anything and everything here, including anything you think may be missing.
For your reference I use my computer for the following: Games, Web Browsing, Movies/TV Shows, Image Editing, Programming/Development. I dont play a ton of games at this point but am interested in getting into TF2, Crysis, etc., etc. Given my mixture of activities, I dont see a significant need for a Q6600 G0, although by getting the 6750 I'm positioning myself to be able to upgrade later on when a large share of applications that I regularly use fully utilize the extra cores.
I tend to think that the extra $100 I save from the quad core is going to the case, which is a more long term investment since my upgrade cycle for the proc/mobo/video cards will likely be much shorter and Ill want a quality case to continue to house the main rig.
The main decision points that Im faced with at this point are:
Motherboard, 680i LT vs. P35 which in turn affects
Video Card, 1 or 2x 8800GT
Total Cost (before shipping):
~$1850 for 680i LT + 2x8800GT
~$1585 for P35 + 1x8800GT
Processor:
Intel Core 2 Duo E6750 G0 Stepping - $194.00
http://www.clubit.com/product_detail.cfm?itemno=A1938254
Motherboard:
eVGA122-CK-NF67-T1 LGA 775 NVIDIA nForce 680i LT SLI ATX Intel Motherboard Retail - $160
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188015
or
GIGABYTE GA-P35-DS4 Rev. 2.0 LGA 775 Intel P35 ATX Intel Motherboard Retail - $178
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128064
Case:
COOLER MASTER Stacker RC-832-KKN1-GP Black Aluminum ATX Full Tower Computer Case Retail - $240
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119121
Power Supply:
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 Retail $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002&Tpk=corsair+620hx
Memory:
2 x Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Retail - $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565
HSF:
ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler Retail - $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
HDDs:
2x SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive OEM - $220
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152052
Video Card:
1 or 2x BFG - NVIDIA GeForce 8800 GT OC Graphics Card - $280 or $560
http://www.bestbuy.com/site/olspage.jsp?skuId=8594381&type=product&id=1190678470708
Optical:
SAMSUNG Black 20X SATA 20X DVD±R DVD Burner OEM - $34
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
Thermal Grease:
Artic Silver 5 Thermal Compound OEM - $6
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Case Fans:
2x ZALMAN ZM - F3 120mm Case Fan Retail - $18
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118008
Thanks for your help ahead of time. Let me know if you see anything missing or think that some of this stuff could be improved.
Processor:
Motherboard:
or
Case:
Power Supply:
Memory:
HSF:
HDDs:
Video Card:
Optical:
Thermal Grease:
Case Fans:
