I plan to do some moderate amount of OCing on my i7 build for purpose of gaming. I wanted a system with a decent amount of expansion for future addons. I'm running a bit over budget at the moment though, with my ideal budget being around $1600 for a full PC system.
Here is the list of my currently planned items.
i7 920 - $359.99
OCZ Platinum OCZ3P1600LV6GK 6GB DDR3 3X2GB DDR3-1600 PC3-12800 - $129.99
Western Digital WD1001FALS Caviar Black 1TB SATA2 7200RPM - $133.98
XFX Radeon 4890 1 GB 850 MHZ - $319.99
Thermalright Ultra 120 Extreme 1366RT - $77.81
ASUS P6T Deluxe - $390.49At the moment I'm at $1422.25. I still have yet to pick up a case, PSU which I'm planning to get [FONT=Verdana, Arial, Helvetica, sans-serif]Corsair HX1000W CMPSU-1000HX 1000W ($319.99), and a DVD burner.
[/FONT]
i7 920 - $359.99
[/FONT]
What kind of options do I have at the moment?
Also, is the P6T Deluxe the right choice for someone who's new at OCing but has aspiration for it, want some room for future expansions?
1) I plan for my computer to be used for heavy gaming.
2) My budget, tax and shipping included, is around $1800 or so.
3) I live in Toronto.
4) I'm hoping to have components that has good performance to price ratio as well as ease of overclock.
5) With the possible exception of a DVD Burner, I don't plan on carrying anything else over from my previous computer setup.
6) My knowledge with overclocking is very low, I plan to read up and understand it more. I prefer a system that is fairly easy to overclock, but still has potential to be very competitive given that I learn enough about it.
7) Monitors, keyboards, and mouse is something I don't have to worry too much about in my budget. I do eventually plan to pick up a 20"-22" monitor.
8) I plan to have my PC built within the next two weeks.
9) I don't know much about the benefits of RAID, but I'd like to have the possibility of utilizing it if I am interested in it once I learn more about it. I have considered the possibility of utilizing Crossfire if I do find my set up to be underpowered, but at the moment I don't have the money to buy a second 4890. If I find a single 4890 to be capable of running well on things like Crysis, Farcry 2, Starcraft 2, Diablo 2, etc, then I'll stick with only one GPU solution.
10) I don't have any legitimate transferable OSes at the moment. Is it still possible to use the Window 7 beta?
