techboydino
- Jun 10, 2009
So it's been a few years since I built my mATX SFF system, and time for an upgrade. I was going to do a SG05 on water but do not like the configuration and would end up cutting it to pieces anyways. I have some ideas on what I need to use but been out for a while and just started trolling the forums to find out the latest and greatest. Here's my idea, ideas, rants, criticism is welcome. Thanks.
1. Machine is built for occasional gaming, and daily use internet, social media, etc..
2. Goal is as small and quiet as possible, ninja like if you will
3. No overclocking needed. I don't care all that much as long as I can play the games I want
4. Money is an object, but the fabrication stuff won't cost me anything really, mostly parts
Instead of cutting up a case I am making one. Using 1/16" thick aluminum angle for the chassis, then will have some sides/front/back cut as needed. probably get some waterjet done once i have the design, i do NOT have access to this and will have to pay for it.
Case chassis will be 8" x 8" x 10"
What's going inside:
-mobo: probably Asus or ASRock Z77 variant
-CPU: Intel i5-3550/3570 or if money allows a Xeon E3-1265L V2 (45W) <--doubtful though
-GPU: Nvidia GTX660
-Ram: 16GB
-HDD: 2 SSD's, 1 Sata (if possible)
-ODD: Slim BR (if possible)
-PSU: Silverstone SFX450 Gold (modular, tiny)
Cooling:
-Swiftech Apogee II (block/pump combo)
-Black Ice SR-1 140mm Rad
-Akasa Apache 140mm fan (push only)
-Technofront Nano Res
-GPU: factory air cool fan
So, with that said I know it's a lot to fit but I think it can be done. Been tossing some ideas around on sketchup...just not sure if the WC setup will fit the bill. Right now in my mATX I am running the closed loop corsair and have no issues on a hotter i5-750, so I was hoping the 140mm would be enough for the newer i5, maybe the NB, and even maybe the GPU? I've seen a thread where someone modded a corsair and is doing cpu/gpu/nb just from that little setup with decent temps...
I pieced this together based on reviews, articles, forums and martins liquid lab results. Happy to hear your thoughts on what will and won't work. Below is my very rough sketch of possible configuration..please go easy, it's been a while.thanks.
not sure why these pics won't embed on to the page
-GPU: Nvidia GTX660
-Ram: 16GB
Cooling:
