Mostly gaming, movies, web browsing, and some coding for school.
Probably about $1000 for the rest of my parts, not really using a budget though.
Boston, MA.
Motherboard, CPU, CPU cooler, RAM, case, PSU, dvd drive
Already have a Sapphire Radeon 7970 and have a Samsung 830 256g SSD in the mail.
6) Will you be overclocking?
Yes, hoping to overclock to 4.5 ghz+.
I'm using a recently bought Samsung S27A750D. 27" 1920 x 1080. 120Hz.
Been planning this out over a few months, but planning to buy within the next day or so.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Mostly just looking for a good overclockable mobo with crossfire support for 2 x 7970's.
64bit Windows 7 Ultimate.
I'm upgrading from a Q6600 @ 3.0ghz. I'm having trouble atm choosing the case, cpu cooler, and PSU. Here's where I'm at in terms of each part:
Motherboard: ASUS P8Z68-V/GEN3. Have read a lot of good things about this board for overclocking and seems to be a reasonable price.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131792
CPU: i5-2500k
Case: Been thinking between the following three:
Corsair 550D - Like that it's quiet, sleek, and cheaper than my other choices atm. A bit worried about the size if I decide on a 2nd 7970 and how cool the case will be on air.
Silverstone Raven 3 - Not crazy about the looks, but read that it has very good cooling and airflow.
Silverstone FT02 - Seems to be a better looking Raven 3. I'm leaning closer between this and the 550D.
CPU Cooler: Been thinking of the Antec 920 based on reviews on this site. Not sure how well it'll fit in the Corsair 550D and have only installed a Zalman CPU cooler previously.
RAM: CORSAIR Vengeance 8GB (2 x 4GB) DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
PSU: At the moment I'll be using just one 7970, but plan to run another in crossfire sometime in the future. Been thinking of getting a 850 Watt or 1050 Watt PSU.
The ones I'm leaning toward atm are:
Thermaltake Toughpower Grand TPG-850M 850W ($40 off atm)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153143
CORSAIR Enthusiast Series TX850 V2 850W (Cheaper than the thermaltake, but Bronze rated instead of Gold rated)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022
I'm really liking the look of the Corsair 550D, but am concerned with the space/cooling and whether or not the antec 920 will fit in it properly. If those won't work together I'll probably go with a Silverstone FT02 with the 920 cooler. Wanted to ask here on advice for this and if anything else I was getting for this build might not be compatible or if any of these parts were overkill for gaming at 1920x1080 at 120hz mostly for Battlefield 3, World of Warcraft, Starcraft 2, Diablo 3, RPGs like Witcher 2 / Skyrim, and possibly Guild Wars 2.
Here's where I'm at for the final build:
Motherboard: ASUS P8Z68-V/GEN3.......................................................$187.86
CPU Cooler: Antec KUHLER H2O 920....................................................$108.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16835209054
PSU + DVD combo: Thermaltake Toughpower Grand TPG-850M...............$160.98
(LITE-ON DVD Burner)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.847596
CPU + RAM combo: i5-2500k + 8gb Corsair Vengeance...........................$254.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.850268
Case: SilverStone FT02..........................................................................$229.00
http://www.amazon.com/SilverStone-A...1?s=electronics&ie=UTF8&qid=1331268133&sr=1-1
Total:............$941.80
OR
Case + PSU combo: CORSAIR TX850M 850W + CORSAIR 550D..........$254.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.858760
LITE-ON DVD Burner:..............................................................................$22.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Total:...........$829.79
Any suggestions? Thanks in advance!
Boston, MA.
CPU: i5-2500k
OR
