My 23" Apple Cinema is on its final death-rows. So as the title says, I'm in the Arch Viz industry (or hope to be) and I need some enlightenment in this area so I can be more self sufficient in terms of researching since I"ll be upgrading hopefully by the end of the year. I've been vicariously browsing this forum the past couple months the overall vibe I'm getting is to be a bit more patient so I'm in no rush. Admittedly however, I only have a surface knowledge of the technological aspects of monitors, so please correct me if I'm wrong on certain things.
My uses are pretty simple, I've since retired from gaming (yea yea blasphemy I know) to focus on my career in 3d visualization using 3ds Max/V-Ray and post production with After Effects and Photoshop, but it will also serve as my tv set for Netflix and Blu-Ray. Anyways, from what I've learned so far 4:4:4 chroma and minimum 60hz is becoming the minimum for the tv/monitor balance, I read somewhere on a different forum regarding the conspiracy about how companies directly don't put this on their tv sets because it would cut into the monitor market, I don't know but it was a interesting when I read that at the time.
I'm currently using a GTX 780 Ti and won't be upgrading anytime soon as my budget is limited to one or the other and I know I'lll have to take this into consideration on the limitations to future proofing which I'd like to do. I know this will effect me in terms of hdmi 2.0 and display port technology but I haven't done much research in that area till now so I'll need advice there as well. Also, I need a consensus between IPS vs TN and matte vs glossy because I keep reading so many conflicting anecdotal stories and it's confusing the hell out of me, but all that matters honestly is it doesn't impact the color accuracy, contrast ratio, brightness, and input I won't mind so much since I'm not gaming much anymore.
What I'll be looking for strictly though is the 32"-40" 4k resolution range since that will be the sweet spot for me in terms of real estate and improving my work efficiency. As much as I love having 2 monitors in front of me because how much it improves my overall work flow, I'd rather just have one large monitor. Also, curved displays... I have no basis for comparison since I've yet to test it for myself, so my question there is will it negative impact images or distort in any sort of way or will actually benefit it? I feel skeptical since it only increases the cost of the monitor and my assumption is it would make all of my images inaccurate. I've been reading up extensively on the Philips BDM4065UC and Seiki Pro SM40UNP and they seem to be setting the tone for what to expect this year from other manufacturers, even though they have their limitations from what I gathered so far.
I'm sure there's a litany of things I'm missing out on, so if you guys want to add anything else, by all means preach that bible to me. And if for whatever reason you guys suggest that I should stick to a monitor only simply because it's better for graphic design, please don't hesitate to enlighten me, and I'll consider it in my overall decision. I won't be back here till later this evening in case anyone wonders why I'm not responding, but I'll follow up with you guys as soon as I do.
Gracias.
Gracias.
