MyFriendFreud7Z0
- Oct 21, 2010
Mid-level gaming mostly. I play a lot of games like Civ V and Empire: Total War so I would like the system to be able to run those at a pretty decent level. Also would be nice to play some FPS. Maybe even Crysis at lower settings.
I already have a build planned out and it comes out to around $650. Mostly I need advice on if there are any parts I can switch out to get a better bang for my buck. I don't want to go any higher than $700 though.
3) Where do you live?
Los Angeles, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
I need CPU, processor, case, ram, dvd drive, power source, and a graphics card. Don't need an internal hard drive.
N/A
6) Will you be overclocking?
Possibly, I've never done it before so I'd just like to buy the system first and figure that out down the road.
I have a Vizio 23" full 1080.
As soon as possible.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
HDMI support
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
I have a legit version of Windows 7 64 bit ready to use.
Since I've never done a build before I thought I'd post this here and let you guys check it out for some advice. Here are the parts that I'm thinking about:
Motherboard: ASUS M4A89GTD PRO AM3 AMD 890GX SATA 6Gb/s HDMI ATX AMD Motherboard
Processor: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT
Vid Card: EVGA 01G-P3-1450-TR GeForce GTS 450 (Fermi) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Power: CORSAIR HX Series CMPSU-520HX 520W ATX12V v2.2 and EPS12V 2.91 SLI Certified CrossFire Ready
Dvd: LITE-ON 24X DVD Writer Black SATA Model iHAS-324-98
Case: NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
Los Angeles, CA
N/A
HDMI support
