- Apr 10, 2003
Adrenalin 2019 Edition 19.7.1 Optional
https://www.amd.com/en/support/kb/release-notes/rn-rad-win-19-7-1
Radeon Software Adrenalin 2019 Edition 19.7.1 Highlights
Support For
Support For
- AMD Radeon™ RX 5700 Series Graphics
- AMD Radeon Image Sharpening(1)
- New feature available in Radeon Settings that can be enabled for DirectX®9, DirectX®11 and Vulkan® games on AMD Radeon RX 5700 Series Graphics. Provides contrast-adaptive sharpening combined with optional GPU upscaling that helps draw out detail and provide crisp-looking visuals.
- AMD Radeon Anti-Lag(2)
- New feature available in Radeon Settings that can be enabled for DirectX®9 and DirectX®11 games that improves input-to-display response time with up to 31% reduction in lag.RS-295
- AMD Link(3)
- Now supports auto-discovery mode and one-tap connection, allowing you to easily connect your Radeon PC and AMD Link App.
- Now supports connections to Apple TV and Android TV with a new simplified TV interface.
- AMD Radeon Chill(4)
- Now supports display-aware tuning which sets frame-rate caps to match your monitors refresh rate providing up to 2.5x more power savings than before.RS-294 Display-aware tuning works with fixed-refresh monitors or with variable-refresh Radeon FreeSync™-capable displays.
- AMD Radeon WattMan(5)
- New power gauge readout available in Performance Metrics Overlay and Radeon WattMan.
- Auto Tuning features now provide a summary readout of tuning changes.
- Settings Snapshot(6)
- New feature available in Radeon Settings that allows you to create, save and load your custom settings and configurations for Radeon Settings.
- Automatic Low Latency Mode(7)
- Allows supported graphics products to communicate with your connected TV and enter low-latency (gaming) mode automatically.
- Graphics driver may not uninstall correctly when using the express uninstall option on some Ryzen APUs.
- Performance Metrics Overlay may intermittently display incorrect colors when being displayed in game.
- Radeon Overlay may fail to appear or invoke when playing DOOM™.
- Radeon Overlay may fail to appear or invoke when a game is running fullscreen on Windows®7 system configurations.
- Some users may be experiencing AMD DLL file signing issues with Easy Anti-Cheat™. A clean install of Radeon Software Adrenalin 2019 Edition 19.7.1 may be required to fix this issue.
- With Radeon Image Sharpening enabled, Radeon Overlay may flicker in DirectX®9 or Vulkan® applications or games.
- Radeon ReLive streaming and uploading of videos and other content to Facebook™ is currently unavailable.
- Audio for clips captured by Radeon ReLive may be corrupted or garbled when desktop recording is enabled.
- Textures in Star Wars® Battlefront II may appear pixelated or blurry when using DirectX®11 API.
- ASUS TUF Gaming FX505 may experience discrete GPU connection issues with devices disappearing from device manager when the system is idle.
- Minor stuttering may occur when playing Fortnite™ during the first few minutes of gameplay on AMD Radeon RX 5700 Series Graphics.
- Valve Index headset may experience flicker when launching SteamVR on AMD Radeon RX 5700 Series Graphics.
- Radeon RX 5700 Series Graphics may experience a black screen during uninstall on Windows®7 system configurations. A work around is to perform uninstall in safe mode.
- Recording clips with Radeon ReLive may result in blank clips on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
- League of Legends™ may fail to launch on Radeon RX 5700 Series Graphics with Windows®7 system configurations.
- Radeon Settings may not appear in the right click desktop context menu on Windows®7 system configurations.
- Radeon WattMan functionality is currently not available in AMD Link for Radeon VII and Radeon RX 5700 Series Graphics products.
- The manual connection method for AMD Link may Intermittently fail to connect on Android TV.
- AMD Link TV may experience video corruption while playing back videos from the ReLive gallery on Windows® 7 system configurations.
- AMD Link TV applications are currently only available in English.
