adding SATAII into an aging system
homIcIde
I need more HD space desperately and would like to keep with the times and upgrade alone the sata2 path. The unfortunate problems is that my dinosaur a7n8x deluxe only has sata150, and its spotty nvidia sata at that. Does anyone have advice as to how to upgrade without getting a new MB? Any good pci cards? TIA
there backwards compatible as far as i know, just get a sata2 and you'll be all set for the future
You are aware that most SATA-IO drives are downwards compatible, aren't you?
I think that most PCI add-in cards should work fine. I would probably get one with a Silicon Image chipset, since they appear to be the de-facto standard, hence are likely to have a long period during which drivers etc. will be available.
i assumed it was backwards compatable, but is the loss of performance significant?
No.
Then again if I remember right that nvidia sata taxed the cpu more then it should. Just pickup a cheap sata controller card if you are worried.
