adding gpu waterblock
Megamilkz
So this video shows my current set up, anybody have sedgestions as to what I should add if i add a gpu waterblock to my gtx 275? i was thinking adding another single 120mm rad, or having a second 2x120mm rad and another pump just to be safe... dont know what order to put it in though, help! :)
http://www.youtube.com/watch?v=o-oauffGVO8
thanks
Just add the gpu block and see what happens to the temps. Then plumb in another rad. if you are not happy, you don't need another pump.
Your reservoir water level looked a little low in the video
