I'm purchasing a Scythe 2-channel fan controller (12 watts per channel) and I'm wondering if there is a simple way to add one additional fan to each channel. Can I just use a couple of these to split the 4-pin female into two 4-pin male connectors, which I can use to bridge the wires for 2 fans that will then connect to the fan controller with a single female connector? Will there be power issues when using only one cable for two fans?
