equinox654
- Apr 7, 2005
I have a 4670k and a z87 Sabertooth.
I have the cpu set to 1.275 volts. During normal usage at idle it goes to .9 volts and at load 1.275 volts like its supposed to. Though if you run aida it will go all the way to 1.37.
Has anyone else seen the behavior and is there anyway to fix it?
