Adaptec AAR 21610SA 16 Ports Serial ATA RAID Controller
Yakyb
for £100 quid this seems a bargain im aware that it only runs on PCI but surely for a Low usage home server this would do the job fine
any one have any experience
Link
You need to have pci-x, it's also got a 2tb limitation, and raid performance from my experience was slow.
Good cheap way to get 16 ports for a WHS build. RAID is slow and you have the 2tb limit like Ockie said above but for a HomeServer application it will suffice.
2 tb limitation is that per drive or per array or all drives total
was really thinking of just getting it for the 16x sata ports (unless there is a better way)
you say raid performance was slow but what about single drive usage.
trying to get a relatively cheapo file / webserver built (all critical backups will more than likely be done to a seperate box)
