What I heard, its pure gloss. Zero AG coating. Its as much glare as the glass ACD.
Monty is right, the tempered glass is even more reflective than the standard glossy. But even the standard may be too much for those who hate glossy.My PCBANK has the tempered glass and it is reflective. You might want to get the monitors without glass.
Level of reflectiveness? A notch less than those silly ultra-glossy laptops, but that's it.Can somebody comment on this screen's level of reflectiveness? Whenever I buy a laptop I always make sure to get a matte or semi-matte display... I hate the glossy stuff.
I've skimmed through this thread so I know that this monitor has no AG coating, but exactly how reflective is it? Is it as bad as those ultra-glossy screens on consumer laptops?
The Crossover also have the best all metal enclosure/frame. It feels higher quality than the other models with easily the best stand. I have 3 of them and would recommend them over the others.
Yeah I really like the "Matrix" design on the back too.
Couple questions before I order.
1. This monitor will work with a GTX 670 right? They only list as high as GTX 580.
2. Is bigclothcraft good? Koreans are pretty honorable as rule but just want to make sure he ships timely. I like his page best because he indicates a 120V adapter will be included.
What source / signal are you using? They're all HDCP compliant so far as I know, so are you referring to scaling ability or what?
I was referring to watching HDCP content from cable via a PC. I have a Nvidia GTX 480 and on older Dell monitors I cannot "tune" in to the premium channels. I am assuming that with these monitors DVI-D would be sufficient?
The Micro Center monitor referenced above has an HDMI port and lists in its specs as NOT HDCP complaint.
Touch Screen No
HDCP Support No
TV Tuner No
Built-in Speakers No
Built-in Webcam No
Stand Adjustment Tilt
Features Excellent resolution and clarity; Beautiful colors; Outstanding performance
Where do you guys see these for $300?
we need to update the title, now its $300![]()
Which one is for 300?
What/ which LCD is the Crossover?
How many people have bought this & found good experiences?
Jesus!! $203????
I think this one is without a control board though??
http://www.ebay.ca/itm/QH270-IPSBS-...0277?pt=Computer_Monitors&hash=item3373c32275
this is the one I ordered, it was $301 then.
http://www.ebay.ca/itm/110833856200?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.microcenter.com/single_product_results.phtml?product_id=0384780Someone over at Anandtech noticed that Micro Center is now selling this. This is an interesting (if not as inexpensive as the current Korean bunch is now) development.
Your long posts aren't amusing in the slightest, rather they are a pain to read, I doubt most get through the first 2 sentences.
This thread has been filled with haters, at least they typed some readable sentences. Go away.
Truly, you guys need your heads examined and then the coconut water fully drained out. [etc.]
It's actually less expensive than the Korean monitors @ $400 because it has a scaler with hdmi, DVI + VGA. The Korean models with scalers are going for $75-$150 more. Thanks for the heads up.http://www.microcenter.com/single_product_results.phtml?product_id=0384780Someone over at Anandtech noticed that Micro Center is now selling this. This is an interesting (if not as inexpensive as the current Korean bunch is now) development.
No HDCP support? Than that's a pass for me. Hand shaking issues are a headache.
Process of elimination, LG is the only company that manufactures 27" 2560x1440 panels, and the 178 degree viewing angles is another giveaway.Do we know for sure that this one is IPS and also doesnt the scaler mean it has input lag?
